mienkuan
- Jul 17, 2016
Provide some test findings that can solve the problem on my laptop.
Symptom:
On windows 10 or 11, playing above 96khz or DSD has noise.
Workaround:
Open the System>Sound page, keep it open or minimize it and don't close it, and set the Default Device to other devices.
Symptom:
Workaround:
So, I got a response from Chord support regarding the white noise I've encountered twice on my Mojo 2, when connected to my Windows 11 laptop, and while listening to YouTube from my browser. Chord said that it was due to wrong settings. My settings are shown in this post.
From the screenshots of that post:
As Chord said, Mojo2 is not a DTS or Dolby decoder so these boxes should be unchecked. And they added: ...realistically, I would lower the output sample rate too...
Furthermore,
Nothing on YouTube is going to be more than 24 bit 48kHz (and the vast majority much less than that). If you are listening direct from a browser, thanks to the truly abysmal setup of Windows 10 and 11, you will need to stop ALL other notification sounds. The noise you hear is a conflict between the sample rate of the notification sound and the sample rate you have requested be sent to the Mojo2 (in this case 384kHz). This can be minimized if you set a 48kHz output (as it is the sample rate of Win notifications) but it is best avoided by turning them off altogether.
So now, I've lowered the sample rate to 48kHz and muted all Windows notification sounds. I did not have time to test this, yet, but I am sure I will not face any white noise issue, further. IF I will, I'll report it here.
When it comes to RFI when my phone is close to the Mojo 2, I have never faced that, but I very-very rarely connect it to my phone.
