Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Mar 24, 2022 at 7:41 AM Post #3,332 of 12,428
My experience with QOBUZ Mojo2 and WINDOWS 10:
after several tests here my experience with QOBUZ:
output devices:
1) ASIO Chord 1.05 as audio output device works.. but only on 44.1 kHZ.. anything else.. got slowed down.. so if you hear a 88.2 kHZ track it will be half of the speed.. a 96 kHZ will be less than half.. It seems is a 5 years old issue.. if anyone knows how to solve it.. let me know.
2) currently the most working one is the Wasapi (exclusive) mode, fun fact.. you may not see in the bottom right menu on the main page, you have to go on settings/music playing/listening preference and set it there... then it will be selected and works.
the ball color change appropriately based on the kHZ. I have experienced few times when i start getting some clicks.. I have to disconnect the mojo and then everything goes well.
another topic: is anyone using the Monarch MKII with the mojo2? what eq do you use?
Mar 24, 2022 at 9:34 AM Post #3,334 of 12,428
Mar 24, 2022 at 1:46 PM Post #3,336 of 12,428
twice the price?..huh?...
Mar 24, 2022 at 2:33 PM Post #3,338 of 12,428
More than twice:
- power consumption at Normal
- battery power
- size
- weight
- over 4 times power
It is more like Hugo2.
Did I mention it has Milf Resistors ?
Mar 24, 2022 at 3:01 PM Post #3,339 of 12,428
diablo if I am not mistaken lists for 899 USD...mojo 2 799...
Mar 24, 2022 at 4:20 PM Post #3,341 of 12,428
Poly can do 768 if you have the right software, like Roon. But AirPlay is limited to 44.1 or 48.
Poly is only good for 354 over wifi. 768 if playing from sd card.
Mar 24, 2022 at 8:46 PM Post #3,343 of 12,428
So am I correct in assuming the MOJO 2 can be paired with an iPhone with just a lightning to usb-c cable ? No silly OTG cable needed ??
Yes, I thought it was too good to be true as well. Used to having to deal with that obnoxious camera adapter with my ifi idsd Signature.
An other reason I’m excited to get one of these!
Mar 24, 2022 at 8:57 PM Post #3,344 of 12,428
Some cables are designed to only supply power for recharging. Some are data and power. Just make sure it passes data.
