so..
has any LCD-i4 + mojo2 owners testify yet?
Very slick but putting the unit on its side, balls up, works very well. Just trying the same with Poly/Mojo 2 and it is responding well. They feel like they run at similar temperatures but I will be hitting them with my FLIR in due course. Come summer and higher temperatures I may mod my original Mojo.Or you can do my Mod. ( https://www.head-fi.org/threads/chord-mojo-modification.945220/ ) to help cooling.
It really works!
Mostly for fun though.
Thanks for the heads up! Now I just need to find this FIIO cable he ordered for my iPhone :|John Darko talking generally about portable sound with wired android or iPhone and PLEX amp. He moves on to what he’s not previously talked about … how he rates the Mojo2. He compares it favourably to A&K SP2000 and iBasso Dx300. And this is in a wired setup … hmmm imagine if mojo offered a non wired option which allowed phones to be used as the owners ONE device they carried with them. I think that will be a follow up video. It’s all in the slow reveal https://darko.audio/2022/02/vlog-portable-audio-in-portugal-w-plex-chord-mojo-2/
You won’t be disappointed. The Mojo 2 sounds great paired with the iPhone..I am thinking about selling my Lotoo PAW 6000 and buy a Mojo 2 to use with my iPhone...
Wise or stupid?
I'd strongly advise you have a listen first. I found the Mojo 2 to be less to my taste sonically than my DAP (Shanling M6). Mojo 2 did some things better (weight, energy, pace), some things worse (detail, nuance, space). To get improvements in both areas, I've ended up going to Hugo 2 which is currently undergoing it's first charge. A watched kettle never boils, a charging Hugo 2 never gets to full charge!I am thinking about selling my Lotoo PAW 6000 and buy a Mojo 2 to use with my iPhone...
Wise or stupid?
lol.. "ok"My Mojo 2 just arrived!
You do know Hugo2 has faster charge with a 2 amp charger?I'd strongly advise you have a listen first. I found the Mojo 2 to be less to my taste sonically than my DAP (Shanling M6). Mojo 2 did some things better (weight, energy, pace), some things worse (detail, nuance, space). To get improvements in both areas, I've ended up going to Hugo 2 which is currently undergoing it's first charge. A watched kettle never boils, a charging Hugo 2 never gets to full charge!
I assume the supplied one is 2A? It's been on for nearly 6 hours! OnePlus warp charge it is not.You do know Hugo2 has faster charge with a 2 amp charger?
White means fast, blue is standardI assume the supplied one is 2A? It's been on for nearly 6 hours! OnePlus warp charge it is not.
Just checked, it's a 2.1A charger. It's not too warm at the moment, so must be close to fully chargedWhite means fast, blue is standard
Spoiler alert: you can use your Hugo 2/Mojo/Mojo 2 when it's charging....Just checked, it's a 2.1A charger. It's not too warm at the moment, so must be close to fully charged. Still glowing white!
I know, but when the instructions say fully charge before first use, I tend to do it. I've got to set it up with the 2go, then it'll be a late night!Spoiler alert: you can use your Hugo 2/Mojo/Mojo 2 when it's charging....
