Anyone had a crack at EQ for the LCDi4? My journey is just beginning.
Chord Mojo 2 EQ settings
- Thread starter tomi1976
Godbluffer
- Dec 26, 2015
For the Focal Utopia 2016 I prefer the neutral setting, whereas for the 2022 version I prefer to turn up the green band 1 dB, and leave the lower bass setting either on neutral or -1 depending on the recording, all to actually make the 2022 sound as much as possible like the 2016, because that one has the perfect synergy with the Chord Mojo 2 to my ears. And oh, yes, I’m in the middle of deciding whether the 2022 is a keeper for me or not, otherwise it’ll be returned.
Hamuraii
Sennheiser HD820
iPhone ProMax and Apple Music
Crossfeed testing ⬤, try and put the mids forward and maybe gain some free extra bass to boot.
EQ Settings @iPaintCode | ⬤ Bass 20 Hz +6 | ⬤ Bass 125 Hz shelf +3 | ⬤ Treble 3 kHz shelf +1 | ⬤ Treble 20 kHz |
Volume Settings: | ⬤ | ⬤ |
Main issue is getting a good seal, stock pads are not good enough for my big melon head.
Does anyone have any preferences in EQing LCD-X 2021 with Mojo 2?
Hi Folks!
I need EQ settings for Hifiman Sundara (2020), Bowers & Willkins P7 wireless and Sennheiser IE 600.
Thanks!
Thanks!
Godbluffer
- Dec 26, 2015
Well, I may have tested the Utopia 2022, which I returned to the store almost a month ago, too much in direct comparison mode, frantically switching between the OG and the 2022, thereby never giving the 2022 the time and space to achieve sufficient brain burn-in, because while using the OG in ‘2022 mode’ - with the green EQ setting on -1 and the red one on neutral or +1 depending on the recording, emulating the 2022 quite closely - for an extended amount of time, I may actually be turning into a 2022 convert after all!For the Focal Utopia 2016 I prefer the neutral setting, whereas for the 2022 version I prefer to turn up the green band 1 dB, and leave the lower bass setting either on neutral or -1 depending on the recording, all to actually make the 2022 sound as much as possible like the 2016, because that one has the perfect synergy with the Chord Mojo 2 to my ears. And oh, yes, I’m in the middle of deciding whether the 2022 is a keeper for me or not, otherwise it’ll be returned.![]()
Do you use any settings for your IE 900 bro?Sennheiser HD820
Hamuraii
Listen to your own ears and have fun.
turbo mode, set all to blue and just lol halp.
you can do a v shape, u shape, w shape.
old tracks, have cross-feed, plus 1, 2 or 3
Warm it up a bit, set yellow up only plus 3
some tracks, bring the singer bit forward, put green plus 1, 2, 3
if the singer is annoying, minus him to, -3
then when your kinda had fun messing around, I just in general have, red plus 3, yellow plus 3 and cross-feed plus 1 [if its old record from the 60s]
have fun.
Hifiman Edition xs
Left bass alone, lifted the bass shelf couple of notches, same with treble shelf, and dropped the treble one notch
Lovely
Lovely
Godbluffer
- Dec 26, 2015
HiFiMan Susvara
Red: 0
Yellow: 0
Green: 0
Blue: 0
Red: 0
Yellow: 0
Green: 0
Blue: 0
B Manoj Kumar
Good People, did anyone try EQing Final E5000 IEMs? I would like to know what EQ y’all using for the supposedly bassy IEM
pattont
Stellias? I EQ with EQMac when using my MacBook, but wondering what everyone is using with just the Mojo 2.
Any settings that present a general improvement in the tone of the Mojo2 (not that I'm not satisfied with the default tone but I believe that it is always possible to improve) and that can be used independently of the phone?
Guy Fawkes
Try this:Good People, did anyone try EQing Final E5000 IEMs? I would like to know what EQ y’all using for the supposedly bassy IEM![]()
Red: +1
Yellow: -1
Green: +3
Cyan: 0
jsk ksj
Lcd-x 2021, my settings are quite basic, any suggestion?
blue +3
red 0
yellow +3
green +2
cyan 0
blue +3
red 0
yellow +3
green +2
cyan 0
