Vidal
Member of the Trade: Asian Provocative Ear
- Feb 8, 2014
Yes, on the Chinese it's in the Lightning connector, on the Apple I'm not sure
after trying several times it seems the problem with Onkyo HF Player is the DOP 3.6MHZ DSD option, if active i have audio cuts.
3.6? there's a mistake.... you are talking about 5.6Mhz dsd x2 right?
consider 1 thing:
I was using a notebook with an i7 4700 CPU, trying to reproduce DSD x1 files through Jriver...I had stuttering.
Scared about this thing, I made some tests...then I noticed that Asusucks energy saving program was limiting my CPU when battery powered....
an I7 4700, with energy saving settings ON, wasn't able to reproduce a dsd file....
morale: maybe it's a CPU problem? what phone are you using?
My Chord Mojo looses connection all the time. I think I found out what the problem is.
The USB cable is not secure in the Chord Mojo. So when I move the Mojo, I loose connection.
Should I send back the Mojo for a new one that hopefully has a more secure fit with USB cables?
Yes I also think that is the major flaw of Mojo, being mobile. Chord are you listening, Mojo should a fixed desktop device and none of these problems will happen.
racebit, the hardcore desktop user.
I'd buy the (presumably cheaper) mains-powered one in a heartbeat. I think there are a lot of people like me who just leave it sitting on their table plugged into a USB brick 24/7.
This is about Mo-bile Jo-y. You must be looking for something else. Perhaps a De-sktop Jo-y ?
