NaiveSound
- Nov 8, 2015
I know it's a package deal, and that it'd awsome all around but would you guys say thr DAC part of mojo is your favorite over the Amp part? Or vice versa?
Guys anyone pairing an iBasso dx50 with the mojo, I wanted to know comparison with ak100 with the mojo.
i think it will sound the same cause the player becomes a transport and all signals are managed by mojo itself
It will sound different, I've tested multiple devices with mojo, all sound different slightly
You need to say in your opinion. I've tested it from several different sources and don't detect any difference.
My Mojo is off while charging. As soon as it is plugged into the charger, the little LED under the charging micro usb port comes on as solid green. While I have not actually timed it charging, the light stays solid green for five to six hours and then goes out. When I turn it on, that little LED (under the charging port) stays off for a little less than two hours and then comes on solid green for the next five to six hours. It then goes to solid red for a little less than an hour when it starts flashing red.
Not really a problem for me, but very different that what was described here and in the user manual about charging.
Just wondering if it was only mine or if anyone else had a similar experience.
This may have been answered since it is pretty hard to keep up with this forum and i haven't caught up on the next 50 or so post but It sounds to me like your Mojo has a defective charge LED. the portion of it that shows white or blue is bad which is why you get green when charging and nothing for the first two hours when it should be blue. I could be wrong but seems logical to me. I would suggest sending it back for repair or replacement if ti bothers you. It really should not affect performance but it is a defect. Good Luck
Originally Posted by Light - Man /img/forum/go_quote.gif
Guys, if we have had a Mojo and are now looking for a step up in overall SQ for a portable dac/amp or even desktop - where do we go from here?
what battery life are you guys getting from your mojo
Guys, I just got my S7 edge a few days ago and have some questions:
1. Is there a way to open youtube audio in USB audio player pro?
2. Am I correct that there is no way to avoid the android upsampling when running apps like Bandcamp?
3. What should I select under the Android sample setting:
This post may cheer you up and put things in perspective...
