Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Feb 25, 2016 at 1:35 PM Post #11,971 of 42,916
Yes I have been charging it on its own and not playing it at the same time and when using it I do not continue to charge it at the same time.
I have several good chargers rated at 1 amp and over and have no such issues with other amps and Daps that I have.
I suggest the highest amp charger you have, mine is 2.5+ Apple one that comes with iPads.
Feb 25, 2016 at 1:46 PM Post #11,972 of 42,916
I think earlier in this thread these were suggested as being suitable. I use my current Motorola Fast Charge for charging my Mojo
Feb 25, 2016 at 1:54 PM Post #11,973 of 42,916
Thanks guys! the highest I have is a 2 amp.
I also used a new portable charger and the Mojo just sucked all the charge from it which resulted in nothing more than heating up the Mojo and then it just switched itself off again when I tried to use it.
I believe Chord recommend anything over 1 amp.
Is the mojo battery a special high voltage/amperage battery as the heating issue and the 10 hour charging requirement is most unusual for a portable device.
I just thought that I would share my experience and I will simply have to return it.
Feb 25, 2016 at 2:10 PM Post #11,974 of 42,916
There has never been a 10 hour charging requirement. Chord quoted that in case of a very large shelf life in the future. 4 hours is much more typical. When the white charging light goes out, it is charged.
Feb 25, 2016 at 2:22 PM Post #11,977 of 42,916
Hello Mojo freaks, I am one of u!
I wonder if I could get some input on which hi end and or giant killer IEMs sound the best with the mojo, I have the 1plus and trinity atlas and both sound fantastic but I wonder if there are any out there that would sound even better. I am not a believer that the most expensive sound better all the time. To me that only happens on some occasions, I have heard IEMs that cost very little and some that cost a lot like the K10 which sounds to ally beautiful but the sound stage is almost non existent. Not trying to create controversy it was just what my ears told me. I prefer the presentation of my cheap Titan 1 to the presentation of the K10, the Titan one is so much more spacious sounding, but the K10 is better tonally. I am looking for one IEM that will do it all if it exist.
Thanks in advance for any input
Try fit ear tg334, it can take a bit of effort to achieve seal once it does, with mojo, is goosebumps all over, tears, all kind of emotional stuff.
Feb 25, 2016 at 2:32 PM Post #11,978 of 42,916
Thanks Kitten-Face!
I will try a few more charge cycles before I give up.
p.s. By any chance is this you or your other half!
Feb 25, 2016 at 2:48 PM Post #11,979 of 42,916
  Thanks Kitten-Face!
I come from a FAR darker place!
https://www.youtube.com/watch?v=zBXWBj7hIzg
Feb 25, 2016 at 2:55 PM Post #11,980 of 42,916
Thanks for the input
That is one of the ones I was thinking of, have u by any chance compared them to the JH different models or the Adell U12?
How is the soundstage on them
I see there is a pair in eBay for $1200
Feb 25, 2016 at 3:48 PM Post #11,982 of 42,916
Please stop posting and just enjoy the music. If I had a Mojo I'm sure I'd use the lower setting, but not to save battery life...
Guy has a question, just answer it or move along. No need to try and regulate the types of questions people are asking.
Feb 25, 2016 at 3:52 PM Post #11,983 of 42,916
Hi guys, I'm interested in mojo and I was wondering the same thing.
Did you discovered if mojo micro-usb Input work with "data only" micro-usb cable? I'd like to keep the connection as clean as possible and I thought that DIY a data only cable for input would be the best choice. I'll be using the mojo with android smartphone/tablet.
thanks!
Actually, for that reason I always unplug when I use the mojo, just uses battery power. Really not anymore annoying than turning it on.
Although mojo senses the 5 volt power at the data In micro USB socket. The five volts goes no further into this input it's just being sensed that it's there. Therefore it can not affect the data on that input in any way as the data goes on into the Mojos circuitry alone and unaccompanied by the five volts who is left standing on the door step as it were!
