fjrabon
- Feb 1, 2009
Any distortion or error at the digital transfer (from the source to the dac) won't matter as long as the dac is playing without any clippings (there are error detection and correction) , the data streaming isn't a real-time thing, every dac got a cache memory that will be used to store some of the data, also if any distorted digital frame came tho the dac, the dac will ask the source to send it again etc....
The distortion at the digital transfer should be addressed only if there are clippings or even stop working.
I'm just saying I have certainly seen interference make a measurable difference with USB cables. This isn't a "woo woo glass stones and magic beads" I've literally seen measurement graphs show it. But gain, that was an extreme case with a bad USB cable in an electronically noisy environment.
I've also certainly seen bad USB ports on a computer make a very obvious and notable difference. Especially if the unit is powered through the USB cable at all. With the m9XX people think it sounds better in high power mode because of the extra power. WHat they don't realize is that they aren't even using that extra power unless they're under 90. on it and the reason the m9XX sounds better in high power mode is because it's running the power through the dedicated cable, and the data cable goes from power+data to data only.
THis is a big reason why the Mojo sounds better than a lot of little DAC/amp bus powered units, because the battery power means that the USB connection is purely data only.
