On some early units was a SSSHHHHHHH like waterfall hiss that comes through the IEM / headphone which is also audible externally when the ear is placed to the unit. It's very noticeable and the exact same sound as through the cable. If there was no input plugged in (USB, coaxial) there was no noise externally or through the IEM / headphone. The same noise was not present when charging, only with USB or coaxial plugged in. That's the noise that had the major issue. The minor sqeek or coil noise or whatever when charging is what Chord is saying is a non-issue and related to the power source according to Chord. You may be getting the two things mixed up.
In the end buy it if you want one and if there is an issue return it to your local dealer.
Thanks once more Relic. That's the full picture I probably didn't get. Still there are some customers reporting noise and others reporting clean of noise. I guess I'll have to try and find a good merchant. I just hate it when a purchase feels like a lottery, and you're relying on the helping hand of a merchant, rather than the manufacturer.
FWIW, to anyone that is reading: are there any among us that can state that their Mojo does not produce any unwanted noises in any circumstance (both the hissing during PSU + USB audio source connected at the same time, as well as no audible coil whine when only a PSU is connected)?
Edit:
My original Mojo (serial M0202XX) had the white noise issue so I had it replaced to a new one (serial M0208XX) which resolved the problem completely.
Both models have the charging whine (not from the headphones but the unit itself making a whine), so it's probably not related to the production batch.
Anyhow, the charging whine only occurs if I use a high current charger, whereas it makes no whine on standard 1A charger, so I'm not too concerned.
According to my USB current meter, Mojo only draws less than 1A during charging, so it's a bit pointless to use the high current charger anyway.
Thank you very much for the information. I'll take that into account when I'm auditioning mine.
