cirodts
- Jan 27, 2016
for now usb-usb I tried then in the next days I will get usb-coaxWhich digital interconnect have you found best from R3 - Mojo? The Hiby ‘USB-C to 3.5 Coax’ or ‘USB to USB’?
https://www.amazon.it/gp/product/B074CMCZQP/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1Can't believe that not even Chord in their "special Mojo cables package" don't provide a coaxial cable or at least a 3,5 mm adapter to connect the Mojo by coaxial....Can't find a proper cable for it.
https://www.amazon.com/Micca-Premiu...704246&sr=8-6&keywords=coaxial+to+RCA+coaxialThat is not what I need. I have a streamer with coxial output and I want to connect the Mojo to use it as a DAC.
Anyone tried if the mojo will work without battery?
wont damage. as if you connect it to PC it will obviously be sending power to the audio USB port. The middle 2 lines are for Audio. the lines on the side are for power in a USB. If mojos audio port's power lines arent connected to the board, then I think it will never damage even if your power source is 10 A. I recently bought a 1 € cable and a FiiO CL06 Cable for the Mojo. I avoided the Shanling cable only because it looked not durable, even though the target audience is ppl who use it portable. There is a review in youtube mentioning that it did not alter the sound. I guess to have an audible improvement , u need a cable like Cinnamon by Audioquest.I’ve done it a few times. No issues. Enjoy!
This is the cable you’re looking for.That is not what I need. I have a streamer with coxial output and I want to connect the Mojo to use it as a DAC.
This adapter will work if you already have SPDIF Coaxial cable.
https://www.amazon.com/gp/aw/d/B0069MLDUO?psc=1&ref=yo_pop_mb_pd_title
https://www.amazon.com/dp/B007JIS35K/ref=cm_sw_r_cp_awdb_t1_fvOeCbZFEZ55S
These are both mono, me thinks....The cable recommended by DjBobby above is the one I want, but they don't ship to my country, unfortunately.
However, it baffles me that Chord didn't see fit to include such a cable or at least an adapter in their "Mojo mega-package" (https://chordelectronics.co.uk/product/mojo-cable-pack/)
They are not mono. Coaxial only uses one line. Look on the back of any DAC. Or output from a CD player, or hifi tuner.
