There have been many posts providing feedback that Apple chargers, Samsung chargers, and Anker chargers work well, so those are the three brands that I normally recommend.
Just to elaborate on the above.
Buzzing of mojo internals.
I have had 3 mojos, all of them started to buzz when charging is nearly finished, the first one, once after I had it for a few weeks, I plugged it in and thought it was going to blow up, the noise coming from it was a REALLY loud clicking sound, it was so loud, I really thought it was going to explode. Dont know what caused that.
All of my mojos buzz when nearing full charge, its happened with apple ipad 2amp charger, anker 4.8amp charger, anker 22000mah battery backup, samsung galaxy charger and others and also when plugged into a usb port on my pc’s.
So, lets narrow it down.
3 mojos ranging from early to mid to high serial numbers, they all buzzed on a variety of chargers connected to the mains and not connected to the mains.
Whats the common factor in all of this ?
Either the mains suppy which if I am correct can be + - 7% of 230v roughly upto 256v
or mojo itself.
I will assume its mojos fault and not a fault with every single charging device I own or the mains power.
If it is all my devices, that means, all my many chargers are broke, my computer”S” are all broke, my monitor is broke, my backup battery is broke, all my houses wall sockets are broke. < house has also been rewired completely and it still happens.
I just think its a flaw intrinsic to mojos design or to one of its components.
nothing else of mine buzzess when being charged.
Harmful ? Probably not as has been said by Chord, annoying, yes and I dont believe that its caused solely by inadequate chargers as per chords advice.
Thats my take on it.
Glad to report that poly nor hugo 2 buzz.
