Fiio X5 (first gen.) still handle very good PCM files (until 24/192 kHz) as transport for my Mojo; unfortunately it doesn't handle native DSD.
Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
- Thread starter Mython
Noobzilla
- Mar 17, 2015
Got my Chord Mojo yesterday. I use foobar and always get a loud click noise when I change track or move the time on the current track :/ Doesn't seem to happen on Tidal.
Try the JRiver player, a trial version is available and see if you get the same issue with that. If not it must be something in your foobar setup or a driver issue.
https://www.jriver.com/download.html
miketlse
- May 8, 2016
I think it is your foobar settings. The answer is probably in the faq in post#3, otherwise search the thread using search terms such a clicks.Got my Chord Mojo yesterday. I use foobar and always get a loud click noise when I change track or move the time on the current track :/ Doesn't seem to happen on Tidal.
WarrenR
- Mar 22, 2011
Can anyone tell me the settings I need in Windows 10 to use my Chord Mojo. I'm using foobar and I have installed the correct ASIO component. All I get is 'Unrecoverable playback error: Could not start ASIO playback'. I managed to get it working just now by changing the Windows audio settings to 44.1khz only but now it won't work again. This is doing my head in as it was perfect on my previous Windows PC.
WASAPI works fine.
WASAPI works fine.
Noobzilla
- Mar 17, 2015
I changed to ASIO instead of using WASAPI. The popping noise when I change track isn't as audible anymore though still there. I notice my Mojo change color when I change tracktime or play a different song, so it must be that causing the slight pop noise. Thanks for the help!I think it is your foobar settings. The answer is probably in the faq in post#3, otherwise search the thread using search terms such a clicks.
YamiKeiren
i have a Mojo, i pair it with HD650, it's nice. but i feel not enough. so i need a amp to make it have more powerful without different voice quality.
greatwhite58
A post saying this crops up every so often and I have to disagree again. I purchased my Mojo to go with my HD650 and I cannot have the Mojo anywhere near full volume so I do not understand when somebody says it is not powerful enough! The sound of the Mojo and HD650 to my ears is superb. So my question is if the Mojo is no where full volume with the HD650 why would you need more power?i have a Mojo, i pair it with HD650, it's nice. but i feel not enough. so i need a amp to make it have more powerful without different voice quality.
RiseFall123
My mojo exactly only 1 hour 30 minutes from blue to green
That’s what my brand new Mojo does, or maybe even before than that.
I purchased my second hand mojo in death battery. I think the owner before me has bad attitude how to treat his mojo battery. That way i can not reach 9 hours usage
I think 9 hours is what I got with mine that is new.
I feel the same with HD600, not enough power from Mojo; Gilmore Lite mk2 will power enough HD650.
greatwhite58
How do you define ‘not enough power’ when you don’t need the mojo at anywhere near full volume?I feel the same with HD600, not enough power from Mojo; Gilmore Lite mk2 will power enough HD650.
I mean not enough dynamics at high volume, it sound congested.
greatwhite58
It sounds amazing to me so maybe my hearing is below par or just aged. Oh well I will never know what I am missing then.I mean not enough dynamics at high volume, it sound congested.
There is any different in battery life using a source via micro USB and coaxial in. I saw some dac/amp in spesification have huge different. I always use phone not a dapThat’s what my brand new Mojo does, or maybe even before than that.
deanorthk
got my mojo for 4 days now, and whaou.... Tried it with fostex TH900 (incredible), and HD650 (not bad at al). All that connected to a late 2013 Macbook pro (core I7/16gb), and playing through Audirvana.
happy owner I am
happy owner I am
Total: 34 (members: 0, guests: 34)
