miketlse
- May 8, 2016
USB C for the M1.Which kind of cable, USB, coax or fo?
What do you mean by boot colors sequence?
Yes it doesWhen you turn on it, and it won’t restore correctly to normal mode, it for some seconds does a sequence of changing colours on the first ball?
is my impression if I change the standard mojo usb cable with another dirty sound?
Yes it does
After Mojo I need a Stationary Amp/Dac for listen classical music and jazz and I have 2 candidates:
Grace Design m900
RME ADI-2 DAC
The two incorporate the AKM 4490 chip.
I am interested in a warm sound to spend many hours without fatigue but at the same time be dynamic and with character.
What do you advise me and why?
Thanks in advance
What headphones did you use to compare the two DACs? It is more difficult to pick up differences with lower end gear.Hi Guys,
today I was doing some A/B tests between mojo & dragonfly black.
I have listened the following albums through the Tidal desktop app with my Noble X:
Chicago Transit Authority
Pink Floyd The Division Bell (HD 24/96 version)
Miles Davis Kind of Blue
Sadly I've noticed that there's no a huge difference between the two DACs.
Please tell me that I'm wrong here, Mojo costs 4 times the DFB...what if I will compare it with DFR (that should be even better)?
