BTW for anyone wondering if that eBay OTG that goes straight from micro-to-C works, it does. Works like a charm.
The right angled one i suggested a while back?
Mojo's battery is custom made for Chord. You can order it from Chord or their distributors. It uses a 2-pin connector, no soldering required.Chord Mojo Battery Replacement.
Now I think I need to replace the battery, anyone knows the exact model number of the battery and where to get it - I am decent at soldering.
Like many others here, I also sometimes have this issue with my iPhone 7. However I don't need to disconnect the Mojo, I just press pause for a few seconds, then play, and the music comes back on!After listening to this briliiant little amp for a few weeks, i really like the quality and features. A little glitch which i always encounter on iPhone is that it somehow 'mutes' itself after a while, but the player continues to play. Not sure why, but i had to disconnect/reconnect pretty frequently. Anyone had this issue? Using iPhone 7+ and Kaisertone.
Another small 'issue' is the sampling rate. Though I read on some other thread that the ball isn't capable of outputting a pure white color while playing DSD, I can't help but to find the light purple very similar to the 768 light shown in the manual. Anyone managed to make it show pure white?
Edit: I solved the mystery of the white ball shortly after posting. The light setting must be set to the brighter setting and seen from roughly 45 degrees with the headphone jacks facing you. LOL!
Still need help with the random 'mutes' though...
Yep. I just downloaded it and will install this evening when I get home.Shanling are beta testing new software that allows you to control The M1 and M2s from your android phone.
More info here https://www.head-fi.org/f/threads/s...nsport-bluetooth-4-0-aptx-dsd.816385/page-181
I'm tempted to try it myself.Yep. I just downloaded it and will install this evening when I get home.
Do you know of any in the USA? If so how much.Mojo's battery is custom made for Chord. You can order it from Chord or their distributors. It uses a 2-pin connector, no soldering required.
I got this recently. Great performance but does anyone experience irregular static cracks while playing? They're somewhat subtle on any track I play.
MP3/AAC on iTunes
