- Feb 11, 2008
You do it you've had it apart now unscrew the board and release it from its lid .... Go on ..Do it .... You know you want to...![]()
Now no one else do that !!! Now very carefully put it back together making sure the T pieces don't fall out. And if your brave enough to show me the serial number it will keep its warrantee.
Now no one else do that !!! Now very carefully put it back together making sure the T pieces don't fall out. And if your brave enough to show me the serial number it will keep its warrantee.![]()
Results from my AK transport optical comparisons
All default EQs and Optical input using the sys concept cable
All sound very good but these are differences
RWAK100 - thickish signature and heavier bass
RWAK120 - Similar to the RWAK100 but not as thick
AK240SS - tighter and better resolving all round, excellent micro detail
AK380 (Un Amped) - same as AK240SS but seems to be a little less bright - this is best for me so far (shame the stack fit is the worst)
I rank the AK transport purley on SQ - based on default EQ and optical input as
BEST
AK380 (Un Amped)
AK240SS
RWAK100
RWAK120
WORST
Just goes to show the ones and zeros are sent in different orders effecting the signatures
By playing with the EQ you can easily see this
I also have an QLS QA360 will try to test when I get time also, but I know already the stack size for that is too big and will look silly IMO
Here you ar
Here you are-unscientifically(no offense meant just stating the fact)-saying there is a difference, even going so far as to rate which sources sounded best.
EXPERTS: Do sources matter? I've heard arguments from both sides and personally side with the more scientific arguments which have come from the "sources don't matter crows". There *IS* an answer to this due to the functioning of the technology, so which is it?
I WANT it to not matter so I don't feel the need to buy anything else, however I want the truth more.
For my ears and IMO -I rank the AK transport purley on SQ - based on default EQ and optical input as
Preferred
AK380 (Un Amped)
AK240SS
RWAK100
RWAK120
Least prefered
YMMV
You need to play with the older AK FWs some are better than the latest.
Here you ar
EXPERTS: Do sources matter? I've heard arguments from both sides and personally side with the more scientific arguments which have come from the "sources don't matter crowd". There *IS* an answer to this due to the functioning of the technology, so which is it?
If anyone answers me, please refrain from "x had more bass extension" or "y sounds better", those are not scientific statements. I'm looking for answers based on the actual operation of the hardware inside the units, not what you hear.
Thanks
It's not an argument.
Something needs to change the data stored on the device into audio data. Even on a CD transport where the output to a DAC should be the same from every player there are differences - with a DAP we are looking at more variables (initial file format, codec, player software, storage medium, etc).
Then subjectively people are saying that the transfer method has an effect too (coax vs toslink vs usb) and that the connectors make a difference too.
Look at your computer and look at what codecs you are using - if it is using v1.00 of every codec then I'll concede the argument(Note I am not talking about DAC or soundcard drivers or firmware, but the codec, the software that converts the file to audio).
If "digital is digital" then none of the above would have any difference.
My guess would be that the guys saying different are assuming that somehow the DAC is reading the data directly from the storage medium.
The question is really *HOW BIG* a difference do different sources make and where do you draw your own limits![]()
That fits easily in a pocket?Just ordered my AK100-mojo link from Sys.Concept. Great customer service
