HalloweenJack23
Formerly known as JohnM-73
John I don't actually think there is likely to be any thing wrong with your unit there are three volume ranges of colour rainbow for volume control you've not got up to the middle range yet keep pressing the up button and when the balls advance through the colour in a stepped sequence your on the middle range until then the plus ball sits at one colour
The wistle your hearing is caused by your charger please try a more powerful one and the noise should become far less noticeable.
Hey John, many thanks for replying (much appreciated).
Well the thing about the colour range issue is that the unit was operating within the middle range at the time - started off in line-mode at 3V, then stepped down a few clicks to around 2V, which should ordinarily be the two blue balls of course. No issues with the sound at all (superb) but the hue of the middle ball was out for sure. It seemed to rectify itself the third time I used the 'line-level' startup routine.
As for the charger, it's already a 2Amp item (a 10W Apple iPad charger) which according to other posts here is more than sufficient power-wise, and one that worked absolutely fine with my original Mojo which worked together silently. The whistle was so loud it actually woke me up last night. Surely not how it should be. I tried it with another charger too and the result was the same, but it seems intermittant; no rhyme or reason.
I'll feel happier with a replacement to be honest.
