Lord Raven
- May 17, 2015
No, the Mojo, and all Chord DACs, are single ended. There is no benefit to plugging the separate headphone jacks to your stereo. Even the RCA output measures better, except for Voltage output, than the XLR output (which is derived from the SE out) in the Hugo TT and DAVE.
As for your connection to the phone, you are likely hearing cellular interference and/or a loose connection with the USB cable in the Mojo input. Unfortunately this loose connection can happen with some USB connectors.
As for charging, yes, you would connect to both the USB ports to charge and listen at the same time. The fact that it takes a long time to charge is not surprising as PC USB ports are not high current ports, especially when you are drawing power while listening. Try using a sperate 2A 5V USB charger plugged into the wall instead. Often times manufacturers may overstate their charger specs, so even though the charger is rated at 1A output they may not quite deliver that amount of current.
Thanks for clarifying the misconception. I will try to play the music putting my phone into Airplane mode and see the results, cables, on the other hand, are brand new to be regarded as loose.
I do have a Samsung Note 3 charger that is 2A, I was afraid to rapid charge Mojo and ruin the battery, was using Samsung S3 charger LOL
How could the battery be so good on this device? Any specification? I want to buy a replacement for the future
I think I would go out buy the Hugo soon, someone please stop me. This is what happens to me all the time.
Rob could have designed a quarter inch jack port, my adapter is about 5 inches long.
