Just got my Qutest in and I’m having some problems with the drivers and settings. Hoping I can get some feedback on this as I’m usually pretty tech savvy and can figure out where my problem is.
So, received the Qutest perhaps an hour ago, plugged everything in, set it up, downloaded drivers and went to the settings of Audirvana to make sure everything was correct and my ASIO drivers do not seem to be showing up correctly. Using windows 11 btw. Originally the device wasn’t showing up in ASIO at all however I needed to finish the install, after I did that the ASIO Chord 1.05 shows up in my output device options, however many of the PCM and DSD frequencies are greyed out and I am not able to actually open up the driver when I click on the little settings wheel next to the “ASIO” option. No issues with sound and it seems to switch sample rates however I do not have all of my available options which bugs me. WASAPI also seems to be showing up fineDoes anyone have a suggestion?
The only issue I can possibly see being a problem is also having iFi drivers installed, but I cannot see that truly being the problem, I can’t be the only person who wishes to be able to switch back and fourth between hardware without having to uninstall and reinstall software every time I do switch… if that is the problem I’ll be quite disappointed.
Including some images in case I wasn’t clear in explanation.
