ecwl
It actually doesn’t matter. When M-Scaler is sending DAVE DSD converted to 705.4kHz PCM signals, DAVE’s DSD/PCM+ filter is not in use. The 705.4kHz PCM signal is just upconverted to 5-bit 104MHz and noise shaped through the 20-element pulse array DAC.If the MScaler converts DSD to PCM, should the DAVE then be set to 'PCM plus' when connected to an MScaler?
Of note, if DAVE is set to PCM+ mode, when it gets PCM 44kHz signal for example, the 164,000 taps filter is in use to upconvert to 705.4kHz first. If it gets a DSD signal, the “inferior to M-scaler“ DSD to PCM conversion occurs to 705.4kHz first.
If DAVE is set to DSD mode, when it gets PCM 44kHz signal, the 82,000 taps filter will be used to upconvert to 705.4kHz first. If it gets a DSD signal, it’ll directly convert to 5-bit 104MHz
