MeetYourMaker
Has anyone compared Chord mDave against Aqua Formula xHD?
Reading the Dave user manual, I understand that Dave has two analogue outputs (XLR, RCA), which are both active at the same time.
Can the volume be adjusted independently for each of these? If yes, would this be possible:
- setting the attenuation for balanced output to fixed level (0 dB)
- setting the RCA output to variable level and using the remote control for adjustment?
Thank youCongrats man, dave looks awesome in black.
Hey Musickid thank you!Congratulations Deano! Are you using headphones or speakers?
There is no audible difference. For some DAVE owners there were dropouts using the M Scaler and the solution was to use BNC 3+4 instead. Beyond that, any claimed differences in sound are baseless nonsense.A quick question over on audio bacon, Jay said that he prefers bnc input 3&4 into the Dave rathan than using bnc input 1&2 has anyone here heard any difference
Your thoughts?
Cheers
Dean
Thank you, I couldn't hear any difference alsoThere is no audible difference. For some DAVE owners there were dropouts using the M Scaler and the solution was to use BNC 3+4 instead. Beyond that, any claimed differences in sound are baseless nonsense.
InterestingWell it is not quite baseless nonsense because BNC inputs 3 and 4 are further away from the Dave analogue outputs so the logic is that any RF noise piggy backing on the BNC cables is nearer to a route into the analogue side of Dave if BNC inputs 1 and 2 are used.
