Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
Setting 1 is about 1 dB boost from DC to 1 kHz; 2 is 1.5 dB, 3 is about 1.9 dB. The LF change is a requirement in order to give the correct time delays for each ear.
I am confident that the change you are hearing is down to the EQ and not a reduction in transparency because the depth perception improves; with DSP if there is a problem in transparency you hear it with depth getting worse as DSP's problem is small signal non-linearity. But with cross-feed on, depth gets much better.
Rob
Rob
