May 24, 2016 at 12:28 AM Post #3,121 of 27,054
Roy,
This is what I am getting as well running Windows 10 off a Macbook Pro using Parallels Desktop 11.
Roon Windows with DSD256 files.
JRiver Media Center also works with DSD256.
Paul
Paul,
Clearly, to be able to use DAVE's ASIO driver is the best bet but as you may or may not realize, with that driver, you are limited only to local playback through your Windows computer.  This means that the functionality of that driver doesn't extend to other devices like the microRendu that you have on order.  In other words, once your microRendu arrives, without Sonore's fix, you would once again be limited to DSD 64 and 128 playback.
If your end goal is to stay with your Windows environment, then you're all set.  However, I believe almost 100% of people who buy a microRendu buy it for only one reason and that is superior SQ, above and beyond what you can get through your Windows PC or Mac and in my personal experience, above and beyond any digital source I have heard (period).  I have no problem using my Mac via optical to watch a youtube video or even listen to an occasional track on Spotify but when I want to sit and really listen to all that the DAVE can provide, then I do it through my microRendu.  Once you get yours, I believe it will spoil you and you will be disappointed when you have to use something else.  To now have the ability to stay with my microRendu for playback of any PCM or DSD file and remain bit-perfect is a wonderful thing!
May 24, 2016 at 12:31 AM Post #3,122 of 27,054
I have to say I am more than impressed with the customer service exhibited by the entire Sonore team of John S., Jesus, and Andrew Gillis. They must be putting in some really long days because everyone and their uncle is asking questions, and many are highly technical issues that require some real thought and work. Kudos to the entire Sonore team.
I agree, Jon.  They are a class act.
May 24, 2016 at 12:53 AM Post #3,123 of 27,054
Over the weekend I set up my just received Dave with the sonicTransporter and microRendu and the sound quality has been amazing. Andrew was extremely responsive and helpful to my questions about some setup questions with the sonicTransporter AP. Great customer service!
I have a Luxman 700 amp and initially used Magnan interconnects. I can't use the hard connector with RCA interconnects as the left channel RCA output is very close to the USB port. A friend had a pair of balanced interconnects and they sounded magnificent. I obviously can't tell if the balanced interconnects sound better because of using the hard connector with the microRendu and using a patch cable with the RCA interconnects? Has anyone else run into this problem? Is there an extended version of the hard connector?
Thank you Romaz for your persistence with the DSD issue. I had a problem this weekend with streaming it and I will try the update on the microRendu
Congratulations again, David!  As we share an identical digital front end (sonicTransporter > microRendu > DAVE), I feel I can relate to everything you're experiencing.
If you have the choice (and you do with your Luxman), I would suggest you stay with your single ended interconnects and avoid using the hard connector.  First, I believe Rob will tell you that this is the connection that sounds the most transparent (but I will admit the balanced connection sounds excellent).  Second, while this hard USB connector sounds as good as all but the most expensive USB cable I tested, it really offers no unique advantage other than it came free with your microRendu.  By no means would I consider it a superior solution.  Furthermore, to use it leaves your microRendu dangling in the air leaving it vulnerable to damage especially as you weigh it down with your ethernet and DC cables.  Without supporting it, you would violate the warranty and while beauty is in the eye of the beholder, personally, I don't think it's aesthetically attractive to connect it this way.  I suspect any of the USB cables you already have in your possession will serve you equally well but certainly, do your own comparisons.  If you're not using a USB cable with special RF filtering capabilities, I would suggest you use as short a USB cable as possible (1 meter or less).  The only USB cable that sounded inferior in my testing was a generic USB cable that was 2 meters long (at least 2x longer than the other cables I tested) but even this cable sounded very good.  I believe a good set of interconnects will make so much more difference in terms of SQ than a USB cable and so I would suggest that you not let a USB cable influence which interconnects to use.
May 24, 2016 at 1:02 AM Post #3,124 of 27,054
The other question that I have is does anyone know any differences in the RCA  versus left and right balanced outputs and is there and advantage of one over the other on the Dave?
The DAVE is intentionally a single-ended (SE) design as Rob felt this to be superior to balanced although he will tell you this required a lot of "figuring out" to make it superior to balanced.  If you stay SE, there is only one op amp in the analog chain and this single op amp performs both I to V conversion and headphone amplification (pretty amazing!).  It's one of the reasons the headphone output of the DAVE sounds so transparent.  If you use the balanced outputs, a second op amp is introduced in the chain as this is necessary to do the SE to balanced conversion and this will impact transparency to some degree.  While you probably will have no complaints should you choose the balanced outputs, "best practices" would suggest that you use the RCA outputs if you can.
May 24, 2016 at 1:49 AM Post #3,125 of 27,054
Actually, Rob's analogue output designs are discrete... no opamps, from everything I've read from him on the topic.
May 24, 2016 at 2:05 AM Post #3,126 of 27,054
There's no way I could make this stuff up.  Here is Rob's response to my question some time ago:
Hi Rob,
...does the DAVE through its SE outputs use only a single op amp (like the Mojo) to perform both I to V conversion as well as drive headphones?
If so, do the balanced outputs use 2 op amps (I to V conversion + SE to differential conversion)?
"Yes its same simplicity as Hugo/Mojo but the single I/V stage has the analogue noise shaper.
For balanced its just a regular op-amp providing the negative signal from the SE I/V stage.
Regards Rob"
May 24, 2016 at 2:20 AM Post #3,127 of 27,054
You are both right - all my Dac's have discrete OP stages, but all use an op-amp as the starting point. So you can think of it as an op-amp that has the op stage replaced with a much better Class A discrete OP stage. The feedback loop around the amp includes the discrete OP stage.
With Dave we have two op-amps and one discrete OP stage, as the SE OP is a 2nd order analogue noise shaper (or nested feedback loop), and this eliminates all OP stage distortion, without compromising transparency (as its still one global feedback path with the equivalence of two resistors and two capacitors).
The solution of replacing the op-amp OP stage with a discrete one works really well, and I use it even when I do not need large current OP's (like 2 Qute). The limitations of today's high performance op-amps are very much in the op-stage.
Getting this arrangement to work (discrete OP stage and single feedback around the OP stage and op-amp) needed very fast OP stages as the OP stage propagation delay adds to phase shift.
Rob
May 24, 2016 at 2:43 AM Post #3,128 of 27,054
Hi Rob,
[COLOR=0000FF]"Yes its same simplicity as Hugo/Mojo but the single I/V stage has the analogue noise shaper.[/COLOR]
[COLOR=0000FF]For balanced[/COLOR] [COLOR=0000FF]its[/COLOR] [COLOR=0000FF]just a regular op-amp providing the negative signal from the SE I/V stage.[/COLOR]
[COLOR=0000FF]Regards Rob"[/COLOR]
As in cheap opamp chips from suppliers. It's just a different definition of op-amp we are talking about.
Originally Posted by Rob Watts View Post
Originally Posted by AndrewH13 View Post
Just a thought. Why do other DAC/headphone amps have amp sections when Hugo/Mojo get by without one, and many including Chord say it is more transparent? Have Chord got the patent for ampless amps :-)
Because they can't using chip based DAC's. Chip DAC's have two current outputs. So you need two I to V converters (amps) then a differential to single ended amp, then a headphone buffer to deliver the current. You also need a lot of analogue filtering wrapped around these amps. So why are normal DAC's so complex in the analogue domain? Two reasons:
1. Silicon DAC's are horribly noisy, as the substrate and grounds are bouncing around due to switching activity. So to counter this, it is done differentially, which means the ground noise is cancelled. It also hides the problems of the reference circuitry, which can't be made with low enough impedance on silicon. This translates to more distortion, and crucially noise floor modulation.
2. Delta sigma converters run at low rates - best is at 12 MHz - this means that there is a lot of noise that must be aggressively filtered out in the analogue section. This also applies with R2R DAC's too as these have even worse problems due to the very slow switching speed.
So to run with a single amp section you need the DAC to be single ended and to run the noise shapers at much higher rates to reduce your filtering requirements. [COLOR=FF00AA]Because the analogue section with Mojo is discrete[/COLOR], I can use extremely low impedance and low noise reference supplies - something that is impossible on silicon. This has the other benefit of eliminating noise floor modulation (actually there is a lot more to it than this as there are countless other sources of noise floor modulation in a DAC). To make the filtering easier, the pulse array noise shapers run at 104MHz - over an order of magnitude faster than normal. There are other benefits to running the noise shapers at 104MHz, principally the resolving power of the noise shaper. Now soundstage depth is determined by how accurately small signals are reproduced. The problem with noise shaping is that small signals get lost - any signal below the noise shaper noise floor is lost information. But by running the noise shaper at much faster rates you solve this problem too - indeed Mojo noise shapers exceed 200dB THD and noise digital performance - that's a thousand times more resolving power than high end DAC's.
If I get time today I hope to publish noise floor modulation measurements showing Mojo has zero measured noise floor modulation. This level of performance does not happen on any other non pulse array DAC's at any price, and its the primary reason why Mojo sounds so smooth and musical.
Rob
I have been seeing some comments describing Hugo as excellent DAC with a good headphone amp. Both comments, in my view, are wrong and way off the mark - and seeing these comments are starting to bug me, so I would like to get it off my chest. So forgive me if I am overstepping the mark - commenting on honest posts about a product I have designed, but I thought it might be useful for Head-fi'rs to read my views.
First, I would like to talk about what as a designer I am trying to accomplish, as it has a bearing on one's opinion of Hugo's sound. Imagine going around CES and carefully listening to all the high end hi-fi on show, so you can carefully listen to all the major high end brands available today. Next, listen center stage row 10 to an orchestra. Now, in my opinion, high end Hi-fi sounds from very bad to absolutely awful compared to live acoustic music. The key difference in the sound is variability - live acoustic music has unbelievable variations in the perception of space, timbre, dynamics and rhythm. Additionally, each instrument sounds separate and as distinct entities. By comparison, high-end audio is severely compressed - depth of sound stage is limited to a few feet (listen to off stage effects in say Mahler first - in a concert the off stage effects sound a couple of hundred feet away but on a hi-fi it is an ambient sound a few feet away). Timbre is compressed - you don't get a really rich and smooth instrument playing at the same time as something bright. The biggest problem is the dominance effect - the loudest instrument is the one that drags your attention away - this constant see-saw of attention is the biggest reason for listening fatigue, a major problem with Hi-fi.
So I am approaching designing of Hi-fi from the POV of accepting that there are enormous differences between conventional Hi-Fi and real music, and that I want my equipment to be as transparent as possible. Now some peoples idea of transparency is to use distortion to artificially enhance the sound, and this is a real problem with listening tests - a superficially brighter sound, giving the impression of better detail resolution, is often distortion. So a real challenge is defining what true transparency is. My definition, is to latch onto the idea of variations - if a modification makes the sound more variable, then its more expressive, and hence more transparent, even if it sounds, in tonal balance, darker or smoother and superficially less impressive. Now, if you think that your Hi-Fi sounds better than live acoustic music - then fine, we will agree to disagree. You are looking for a sculpted sound, not a truly transparent one, and I would strongly advise never to buy equipment designed by myself, as I am striving for equipment with no added sound.
So how does this relate to Hugo? Hugo was on the tail end of a long series of incremental improvements in digital design. I have spent the last 7 years on R and D to fundamentally improve aspects of DAC performance - improvements in the jitter rejection, RF noise filtering, noise shaper topologies, WTA filter length, analogue design plus a lot of other things. Moreover, Hugo took advantage of a big step forward in the capabilities of FPGA's - I could do important things that I knew influenced the sound but that previously were not possible due to FPGA limitations. So Hugo was at the confluence of two events - a big step forward from 7 years work in understanding digital design plus a major step forward in FPGA capability. It is just an accident that it happened with a portable headphone product.
So Hugo was the first instance when all these improvements came together. When I finally heard the pre-production unit with all the improvements in place I could not believe the sound quality improvements that I first heard. It completely changed my expectations of what was possible from digital audio - I was hearing things that I have never heard from Hi-fi ever - in other words, the gap from Hi-fi to live acoustic music was suddenly very much closer. Most notable was rapid rhythms being reproduced with breathtaking clarity - before piano music sounded like a jumble of notes, now I could hear each key being played distinctly. The next major change was timbre variations - suddenly each instrument had their own distinct timbre qualities, and the loudest instrument dominance effect was gone. Also gone was listening fatigue - I can listen for 12 hours quite happily.
But by far the biggest change was not sound quality, but on the musicality. I found myself listening and enjoying much more music, in a way I have never experienced before with a new design (and anybody who knows something of my designing career knows that is a lot of designs).
So my conclusion is this: Hugo does things that no other DAC at any price point does. Now I can say readers saying, well OK he would say that anyway, it's his baby. True - I can't argue with that POV. But let's examine the facts:
1. The interpolation filter is key to recreating the amplitude and timing of the original recording. We know the ear/brain can resolve 4uS of timing - that is 250 kHz sampling rate. To recreate the original timing and amplitude perfectly, you need infinite tap lengths FIR filters. That is a mathematical certainty. Hugo has the largest tap length by far of any other production DAC available at any price.
2. RF noise has a major influence in sound quality, and digital DAC's create a lot of noise. Hugo has the most efficient digital filtering of any other production DAC - it filters with a 3 stage filter at 2048 FS. The noise shapers run at 104 MHz, some 20 times faster than all other DAC's (excepting my previous designs). What does this mean? RF noise at 1 MHz is 1000 times lower than all other DAC's, so noise floor modulation effects are dramatically reduced, giving a much smoother and more natural sound quality.
3. The lack of DAC RF OP noise means that the analogue section can be made radically simpler as the analogue filter requirements are smaller. Now in analogue terms, making it simpler, with everything else being constant, gives more transparency. You really can hear every solder joint, every passive component, and every active stage. Now Hugo has a single active stage - a very high performance op-amp with a discrete op-stage as a hybrid with a single global feedback path. [COLOR=FF00AA]This arrangement means that you have a single active stage, two resistors and two capacitors in the direct signal path - and that is it[/COLOR]. Note: there is no headphone drive. Normal high performance DAC's have 3 op-amp stages, followed by a separate headphone amp. So to conclude - Hugo's analogue path is not a simple couple of op-amps chucked together, it is fundamentally simpler than all other headphone amp solutions.
This brings me on to my biggest annoyance - the claim that Hugo's amp is merely good. Firstly, no body can possibly know how good the headphone amp in Hugo is, because there is not a separate headphone stage as such - its integrated into the DAC function directly. You can't remove the sound of the headphone amp from the sound of the DAC, it's one and the same.
Struck by these reports, I decided to investigate, as I see reported problems as a way of improving things in the future. I want to find weakness, my desire is to improve. So I tried loading the OP whilst listening on line level (set to 3v RMS). With 300 ohm, you can hear absolutely no change in sound. Running with 33 ohm, you can hear a small degradation - its slightly brighter. This is consistent with THD going from 0.0004% to 0.0007%. Note these distortion figures are way smaller than desktop headphone amps. Also note that with real headphones at this level you would be at typically ear deafening 115dB SPL. Plugging in real headphones (at much lower levels) gives no change in sound quality too. This has been reported by other posters - adding multiple headphones to Hugo does not degrade sound at all.
So how do we reconcile reports that desktop headphone amps sound better? I don't believe they do, its a case of altering the sound to suit somebody's taste. Now as I said at the beginning of this post, that is not what I want to do - I want things to sound transparent, so that we can get closer to the sound of live acoustic music. Adding an extra headphone amp will only make things worse as extra components degrades transparency. Another possibility is that people are responding against Hugo's unusually (for a headphone amp) low output impedance of 0.075 ohms. Now, compared to headphone amps of 2 to 33 ohms impedance, this will make the sound much leaner with less bass. Additionally, the improvements in damping can be heard as a much tighter bass with a faster tempo. So if you find your headphone too lean, the problem is not Hugo's drive - your headphone is just been driven correctly.
Just to close to all Hugo owners - enjoy! I hope you get as much fun from your music as I have done with Hugo.
Rob
Thanks for clarifying Rob as I was typing my reply below. This clears things up for me as far as terminology is concerned for future reference. Cheers!
May 24, 2016 at 7:43 AM Post #3,129 of 27,054
  I have no practical experience of OSX - Matt from Chord handles all that testing. Actually I was talking to him on Friday about native DSD (non DoP DSD) and OSX and he wasn't aware of any way to do it with OSX.
The problem with UAC2 USB (that's the driverless USB) is that it does not handle faulty data - with Windows, the driver re-sends the data in case of an error. I have never had a single glitch with JRiver on DSD64 and DSD128, and nothing with DSD256 and DSD512 using Foobar and native (non DoP DSD).
Windows 10 with Chrome is another story though...
Rob
Amarra Plus can do both kinds of DSD transmission -- native or DoP. The latter should use effectively no processing, as it is just a PCM-like container with the DSD data inside, necessary for passing it through equipment that needs to see PCM packet headers and the like. If you're seeing a lot of CPU in something like the Roon player, then it is due to re-sampling as someone pointed out.
I'm borrowing a DAVE next month. I'll try it with DSD and see how things go.
May 25, 2016 at 3:47 AM Post #3,131 of 27,054
Folks, why the amazing preamp in Dave is so darn good? Like to hear its secret.
Because it's so simple and transparent to the DAC. A good place to start is to read all of Rob Watts' posts as he has shared a mountain of information on his designs.
May 25, 2016 at 8:28 AM Post #3,132 of 27,054
Dave has entered the building.. for the 3rd time. This one I've paid for, so just as well I'm getting on fine with it.
I won't bore you with my second round of burn-in impressions (because not much to say), but I will bore you with cable talk:
Firstly, I've proven again to myself that my TQ balanced cables to my fully balanced BHSE sound significantly better than my more expensive Transparent SE cables.
The Transparents have served me well over the years, but I no longer need their slightly softening/dulling effect. Transparency and openness is now king for me - my system is good enough not have to tone down harsher recordings. The conclusion I think is that, whatever the theoretical advantages of Dave's SE output, this is more than cancelled out by the input design of the amp, or by the quality of the cable itself.
Secondly, based on others recommendations, I've just had delivery of the Mapleshade optical cable. to compare with my still-on-loan AQ Diamond and Dave's stock optical.
Last time round, I thought that the AQ sounded better than a low cost optical cable (not Dave's), but that was only brief impressions, so in the next week or two I'll be able to do a more conclusive comparison.
And hopefully the Mapleshade will confirm its promise and save me lots of money compared to the AQ.
May 25, 2016 at 1:20 PM Post #3,133 of 27,054
Tonight i have tried my LG CD transport to Chord Dave
My April Music CDA 500 Still with my friend now
Source :
LG CD Transport
Dac / Amp :
Chord Dave as pure DAC
Pre amp :
Tube Pre Amp T+A P 10.2
Headphone :
Abyss 1266
Cable :
LG CD Transport to Chord Dave use
Coax Ztrone Shunyata phyton Digital
Chord Dave to T+A P10.2 use
RCA Shunyata Ztrone Anaconda
These set up is my Ultimate desktop set up now
With my April Muaic CDA 500 sound much better than my LG CD transport only $120 USD
May 25, 2016 at 2:08 PM Post #3,134 of 27,054
I recently received a pair of High Fidelity Cables MC-0.5 Magnetic Wave Guides in the mail. The purchase price was 549.00 USD plus shipping. I first plugged both Wave Guides into my PS Audio Power Plant 5 power conditioner and then went off to dinner. I should state this particular setup is in my family room with a Sony XBR 1080p flat screen, Motorola cable box and OPPO BDP 103D attached. From the music side I have a Marantz PM KI integrated receiver being fed by a Geek Pulse Signature Edition DAC, with music data input from an Auralic Aries LE. I use DAVE exclusively for headphone listening in a different room.
After dinner my wife and I sat down to watch television. The video quality was astounding. I thought that I had traded up to a higher resolution television. I'm not saying that the picture was 4K quality but it was immediately and remarkably better than the already high quality Sony XBR 1080p without the Wave Guides in place. We next resumed watching "The Jewel In the Crown" through the OPPO. The picture from this DVD is grainy in keeping with its origins as a circa 1984 television production. With the Wave Guides in place there was still a grainy picture(you can only get so much improvement from an old video, after all) but again noticeably much less so.
The next day I listened to a variety of music, obviously through the music portion of the same system. I was again immediately impressed. The key aspects were the increase in detail and soundstage, the improved transients, the noticeable natural slow decay of music at song's end and the very silent background. The strings and bass guitar were also better integrated into the whole on listening to the Beatles' "I Am the Walrus," for instance. The timbre of the bass was more subtle and lifelike on listening to Piltch and Davis' "Take One." Instruments were both better isolated and yet better integrated into the whole, and the interplay between musicians became more apparent and enjoyable. In sum, the delta in performance between the Geek Pulse SE(which is certainly no slouch) and DAVE had clearly narrowed, at least for the moment.
And then I tried the Wave Guides with DAVE. Everything I said about the sound with the Geek Pulse SE was again true with DAVE in place, however, the "magnitude"(pun intended) was so much greater. This was money clearly well spent. At this point, I am looking to purchasing another pair of Wave Guides in order to have them available in each system. I am also beginning to put money aside for an HFC CT-1 power cable(2000 USD) and MC-6 Hemisphere power conditioner(2800 USD) to connect to DAVE. The HFC magnetic RCA adapters(549.00 USD) are also on the horizon for pairing DAVE with my Blue Hawaii amplifier. Of course, I'd prefer the HFC XLR interconnects but they are prohibitively expensive at 4400.00 USD, I believe for one(!) if I'm not mistaken. I could also use CT-1 RCA connectors but, again, that would be an expense that I'm not willing or ready to incur(an additional 1600.00 USD) for an already very expensive headphone setup. I know there is no such thing as "end game" in this hobby but, with this setup, I think I could much more than "make do" very nicely.
Thanks to Romaz for introducing me to High Fidelity Cables. As they say around here, "welcome to HeadFi. I'm sorry for your wallet."
Esau
May 25, 2016 at 2:27 PM Post #3,135 of 27,054
Esau
Thanks, Esau, for your impressions. I already own the HFC CT-1 Enhanced interconnects, which I will be using with DAVE (when it arrives, hopefully very soon). I should add that I'm also a big fan of interconnects made by WyWires.
This is probably a question mainly for Roy, who has had the most experience with HFC products. Since the MC-0.5 Magnetic Wave Guides and the Magnetic Adapters that you can use with existing interconnects are about the same price, which do you see as providing greater bang for the buck? Does it come down to specific implementations within a system? Perhaps these magnetic components have different effects on different components? In any event, I'd be interested in this particular comparison, as I imagine others might be also since these are the most affordable HFC products one can buy.
  • Back
