Thanks, Jawed, for explaining!
I have always asked myself what exactly this «Pulse Array» could be. Now it turns out to be based on
Pulse Width Modulation (PWM), which I happen to be somewhat familiar with.
From above Wikipedia link:
«A simple method to generate the PWM pulse train corresponding to a given signal is the intersective PWM: the signal (here the red sine wave) is compared with a sawtooth waveform (blue). When the latter is less than the former, the PWM signal (magenta) is in high state (1). Otherwise it is in the low state (0).»
The German Wikipedia version adds: «For sufficiently inertial consumer loads the voltage curve functions as a sine curve.» Which means you just need a low-pass filter for D/A conversion (as in class D amps).
