ObjectiveSubjectivist
Previously known as alxw0w
Were you using mojo with USB input?Interesting because when I change out the mojo the sibilance is gone.
I thought he measured his 360 and said it was meh.I wonder why Amir hasn’t yet managed to measure his Mark Levinson amps![]()
What did you replace mojo2 with?
Ok and headphones? Or you are using speakers?Optical
My reaction everytime amir posts one of his reviews. It's literally comedy reading what he writes.Looks like DAVE just got it's ass handed to it,
https://www.audiosciencereview.com/forum/index.php?threads/chord-dave-review-dac-hp-amp.35974/
Who cares. He runs some basic tests and ranks dacs based on dynamic range. You can safely ignore his listening impressions and conclusions and focus just on the test results. Good results don’t mean good reproduction and bad results mean there are engineering issues and may or may not be audible.I’ve seen no review of his own extortionate amplifiers…..why would that be….
Sounds about right. You can try various filter, isolation transformer, AC regenerator and dedicated switch or any combination. YMMV.It is a couple of months since I changed the TT2 with the Dave, I use it in a 2 channel system. I like the sound result a lot, it gives for me the "home" effect. Accuracy, detail, timbre, and as you know better than me ....... Premise: I have a very normal electrical system at home, nothing dedicated, I use the supplied power cables. I noticed that during the working hours the sound gets worse and not a little. From 8 pm to 8 am and on weekends, especially on Sundays the sound result is simply wonderful. What do you advise me to do? Can a mains filter help me?
Can someone please tell me how can I show my devices on messages?
A mains filter might have only a marginal effect as these are passive devices. You probably need a mains regenerator. This takes the mains, in crude terms in effect basically using it to power a high-quality oscillator which is effectively used as the input of a power amplifier. Your kit is then fed mains voltage and frequency from that amplifier.It is a couple of months since I changed the TT2 with the Dave, I use it in a 2 channel system. I like the sound result a lot, it gives for me the "home" effect. Accuracy, detail, timbre, and as you know better than me ....... Premise: I have a very normal electrical system at home, nothing dedicated, I use the supplied power cables. I noticed that during the working hours the sound gets worse and not a little. From 8 pm to 8 am and on weekends, especially on Sundays the sound result is simply wonderful. What do you advise me to do? Can a mains filter help me?
Tap on your profile icon at the top of the page and then tap "signature" - it should be easy from there.Can someone please tell me how can I show my devices on messages?
