Sampajanna
Interesting, cuz my troll meter is at the same level…People said the same thing about Synergistic Research HOT. My BS meter is maxed out at this point.
It would be good idea to make some mark (for example red dot on top?) on a molex connector to prevent possibility of reversed connection.Got the first batch of ac inlets ready for farad for the first lps dave systems. Made these first by hand he will probably will making the rest automaticly but these are artisan made by me, alot of patience by and hand finish work. First member here has ordered as set so hope he enjoys it soon.
And added the install manual for those who like to see upfront how that will go.
I'm talking about molex connector. Since it could be inserted in both ways it would be nice to put a red dot (as marked on screen) so it facing back of the Dave.Every lead has a label with the dc voltage on it corresponding with the label on the power supply. In my peronel version i used colored tape when i switched alot but when your color blind and alot of guys are you are screwed. So mattijs wisely desided to go for labels with proper info on it.
Ow and the monitorprint is just there to prevent damage when dc voltage goes off the deep end or beeing switched. Etc etc… so we have covered all bases.
Wouldn’t you have said the same about ethernet cables?People said the same thing about Synergistic Research HOT. My BS meter is maxed out at this point.
We are talking about a RCA/XLR plug that goes on the unused output (this is very problematic and could damage the driver long term) that is not even in the analog signal path that is claimed to have “But this is truly component level change”. Give me a break. If this is not total BS I don’t know what is.Wouldn’t you have said the same about ethernet cables?
Aah ok but that has an edge on the lower one side end what will click in the bottom. If you turn it around the thick side will rubb and it will not go in gently to my knowledge. You probably now that. If they follow the pictures it cant go wrong. You cannot do the conversion drunk or toxicated
Last time I was chatting with certain affiliated person, we were both amazed at the group of “passionate” users of Chord productsIt looks neat though.
Chord could put it on Daves Accessories page aside the stand
Can I see your face chesebert ?Last time I was chatting with certain affiliated person, we were both amazed at the group of “passionate” users of Chord products
No thank you. Not running for office here I will let you know when I’m ready to kiss some babies (wearing headphones)Can I see your face chesebert ?
I’ll be thinking about you, I think I know what you look like, cheese + Bert.No thank you. Not running for office here
ToucheI’ll be thinking about you, I think I know what you look like, cheese + Bert.
The DAVE display is pretty awful. It is either ditchwater-dull or garish. The resolution of the text is poor - either a higher res display should have been used or a sans serif font used that would make the resolution shortcomings of the display less painfully apparent.I wished there was a Display 5 setting so it would not illuminate each time the sample rates change or the playback is resumed. It would be ideal if it only illuminated when a button on the DAVE or remote was selected.
