But why does timing when the dac (all dacs pretty much) do their own reclocking anyway). Even if the Phoenix did something that actually improves the sound, the pricing is ridiculous. You can get a pair of B&W Formation Duo's as an all in one system (which i'm considering for my next place where i won't have any shared walls) for more or less the same money.The difference that a PhoenixUSB is doing is simply not polluting the DAC with noise and provide a very well timed signal with very low phase noise. It enables the DAC to work at its best."
It’s also possible on your sources, the differences are more subtle. I’m currently leaning in the direction you don’t need a great source, just not a ***ty one for the Dave or mscaler. Rob tests with his laptop but I believe only when it’s running off battery. I’d test battery vs plugged in on my MacBook Pro if it weren’t for the fact the battery can’t hold a charge anymore and dies when unplugged.
At this point, my current setup sounds right. I’m truly not trying to improve the sound anymore. The new streamer is just to replace outdated laptop and have something stable. Over last few days I’ve been enjoying my music more than ever.
Well i also tested with my dell xps 13 and my macbook pro 16 with the same results. My pc is plugged into the same mains filter as Dave but i doubt that has any influence on the matter. In the beginning i did slightly prefer optical even to the macbook pro off battery. I have nothing against streamers if you need a streamer, i just remain unconvinced of the sound quality benefits (which isn't even the focal point of their advertising). Especially over optical out of pretty much anything.
