MarkParity
Formerly known as User9876
I have Roon and don't use it with Poly or 2Go and can detect no difference in sound quality between Roon and Airplay or MPD or DLNA.
Remember our brains do all of the listening or processing of what our ear sensors detect, Human ear sensors are relatively very poor at what they do, if you know its Roon or Airplay or whatever or 512 DSD or 44.1Khz PCM your brain may well work out that one is better than another, if you can train your brain to tell you there is no difference you will be as happy as I am.
Other than the convenience of having no cable there is no difference between feeding Mojo from Poly, it sounds the same, the same great DAC just a difference in how its fed with digital data.
Some people's brain's will also compel them to buy a $2,700 IEM cable because it "sounds" better, perhaps its the cost of ownership that makes it "sound" better in this case.
