Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Jun 10, 2020 at 6:55 AM Post #15,362 of 18,821
Jun 11, 2020 at 7:48 PM Post #15,363 of 18,821
I factory reset, renamed, changed my tidal password, tried ios, android, bitperfect on/off, wifi, phone hotspot, at least 5 different dlna apps, etc, and tidal Still is saying "service login or communication error" for my music, while general categories show but won't play... Please Fix My Poly, I use tidal almost exclusively and I don't use an ios phone (an ipad air 2 that I hadn't used in a long time was unearthed to serve the poly), so please either fix tidal integration, or add Chromecast Integration... Below I included one screenshot from hificast, and another from bubbleupnp
Jun 11, 2020 at 10:16 PM Post #15,364 of 18,821
Yeah, sure would be nice to have Poly work with Amazon Music, but I suppose that's wishful thinking. Was hoping Chord would gradually add more features to Poly, but unfortunately that doesn't seem to be happening.
I don't think that's on Chord. Amazon has to make their triggers available and I can't imagine that Amazon cares about our subset...we are just too small.
Jun 12, 2020 at 1:13 AM Post #15,365 of 18,821
Oy oy,
Maybe amazon wouldn't, but the people who are at the top are pretty likely to have expensive systems: if only because when you have that many resources the value proposition changes from what can I afford to what exists.
Jun 12, 2020 at 1:55 PM Post #15,368 of 18,821
If the executives who can afford top notch systems care, then the subsets size doesn't matter
I suppose...Amazon is a bit of an odd company. Proposals can be made by anyone. Its more bottom up than top down. Younger workforce all working a ton and paying a lot for housing. There was someone in the London office who wanted to know about my Shindo but its mostly an apple wireless crowd.
Jun 12, 2020 at 2:21 PM Post #15,369 of 18,821
Which one, do you have a link for "black leather sleeve" ?
I have this one. Its not necessarily leather, It's some sort of fabric that feels like leather.
Not a good case imho - offers zero side protection. Much prefer the black leather Valentinum one which I've had on for donkeys now and still looks like new, as well as protected the unit - though not sure if they're still making them.
I don't think you can get slimmer than the OEM sleeve. All the other cases I've put on (including the Van Nuys one) really do not make the Mojo/Poly portable anymore IMO.
Can you link me to the case that you have?
Jun 16, 2020 at 12:25 PM Post #15,371 of 18,821
Poly will work with Google Cast which is basically the Android equivalent of Apple's Airplay system.
This means you can just 'cast' your music from any app that supports Google Cast to Poly.
So for Tidal you just press the cast button, select Poly and then your Tidal music will play via Poly to Mojo.
There is a good article on the computeraudiophile website which explains how it works with Tidal but it is similar for other music playback and streaming services:-
http://www.computeraudiophile.com/f...aming/tidal-now-has-chromecast-support-29113/
Hi John,
I would really like an update from you, on a feature you promised more than 3 years ago.
Thank you!
Jun 17, 2020 at 1:54 AM Post #15,374 of 18,821
