wirefriend
- Jan 10, 2014
I tried D8000Pro - yes, they are as uncomfortable as D8000 on my head (no improvement there). Sonic-wise they have better controlled lows (D8000 non-pro had some unacceptable resonance in lows). So this part was clearly improved. Still, a bit too much lows for me there. I use HE1000SE now and they have more air but are a tad bass shy. Something between D8000Pro and HE1000SE would be the best. I think I will tune HEkSE by using thick, pure copper cable.I haven't, i was dead set on it when it first came out, but reports of it being uncomfortable and virtually no way to try before i buy it turned me off it. Did you find it a good pairing with Dave? I'm a bit concerned about it and LCD-5 being too neutral to be enjoyable (as i found to be the case with HEKSE) . Also reviews make it sound like LCD-5 is better across the board, while also being more comfortable. And that i can listen to for myself (When my dealer finally gets a pair in stock, they're being bought before they hit the store atm).
If i you wouldn't know you could assume they are closed backs by the look, does that design have any impact on the noise leakage/isolation compared to other open backs?
Can't wait to hear Anni as it is told to excel at lows, so perhaps that cable will not be needed?
