Chord 2Go & 2Yu Wired/Wireless Network streamer and S/PDIF adaptor - Official thread
Feb 26, 2021 at 5:36 AM Post #5,071 of 6,314
Don't ask where or when, its just a date that may well slip. We should just be happy that future updates are coming and 2Go users are still fully supported.
Just guessing but the next F/W may well be released to support 2yu, if that's the case then the answer to "when do we get the F/W" is the same as "when do we get the 2yu"
Lol ok
Feb 26, 2021 at 5:39 AM Post #5,072 of 6,314
There haven't been many 2Go updates :wink:
"Still" supported- I would have been really, really disappointed if it wasn't.
Feb 26, 2021 at 9:05 AM Post #5,073 of 6,314
Lovely! Even came with an ethernet port dust cover.
Thanks @PhilW of Audio Concierge, I am probably among the first to receive theirs!
Feb 26, 2021 at 9:40 AM Post #5,075 of 6,314
A job well done- it has been thoughtfully designed and will product the pair well. Port cutouts are all well done too.
Feb 26, 2021 at 9:48 AM Post #5,076 of 6,314
Today's work from home- or should I say pretend to work- set up is just ridiculously engaging.
Hugo2Go+Ra 21-C with my custom eartips. Sounds pretty close to my Focal Utopias, which is just crazy for an IEM.
Feb 26, 2021 at 10:54 AM Post #5,077 of 6,314
So you got the one with the carry strap?
Feb 26, 2021 at 11:00 AM Post #5,078 of 6,314
Feb 26, 2021 at 11:01 AM Post #5,079 of 6,314
So you think they are a good sonic match with the Hugo 2go?
I'd also like to know how good they are at excluding ambient noise. With those little holes aren't they close to being open-back? I'd want to use them on planes and other public transport as that is a major use case for the Hugo 2go for me.
I ask because I saw a review that questioned their ability to exclude noise.
Feb 26, 2021 at 11:03 AM Post #5,080 of 6,314
No. Would never carry £2.8k worth of gear around like that.
I just mention it because your pictures have the D rings attached to the case. 🤔
I need those D rings 😀
Feb 26, 2021 at 11:29 AM Post #5,081 of 6,314
The synergy is absolutely fantastic and the Ra sound slightly better with the Hugo 2Go than with the Astell&Kern SP2000.
They are, however, open back IEMs. Definitely not something I would use on a plane as it would disturb others.
Getting a good enough fit/seal means outside noise is not a problem- to the listener, at least.
I see that you are also based in London and would bet @PhilW can provide you with a demo to test- that is how I got mine. Price is way too high for a blind buy.
Feb 26, 2021 at 11:36 AM Post #5,082 of 6,314
Haha! I am pretty sure that those come with the case as standard :p
Feb 26, 2021 at 12:37 PM Post #5,083 of 6,314
Feb 26, 2021 at 12:40 PM Post #5,084 of 6,314
Ah, interesting! Seems like I got a bonus :))
