So you are saying that based on your tests running H2 with HQP.... the same music streamed to H2 sounds worse when running HQP??I think that the purpose you buy a Hugo 2 is for what Rob Watts has achieved with digital conversion. While I've experimented with HQPlayer and the Hugo 2, nothing produces the clear sense of depth of the stock set-up the Hugo 2 has. Every type of up-sampling I've tried has sounded poorer.
Therefore what you are really saying is ANY upscaling into H2...OTHER THAN MSCALER.... would make the H2 sound worse??
amyone else care to comment on this? I will need to run a more detailed analysis as it seems that Roon upscaling into H2 actually sounds better... however I have not ruled out psychoacoustics... will need to examine closer.
