gryffe
- Jun 11, 2014
I'm still losing network connection every so often. Anybody else?
So a bit ago I said that vinlypopsandclicks was better with the firmware update. Gonna have to retract that. I sometimes get stretches with nothing, but when I do get them, it's sometimes multiple times in a track, which can get pretty darn annoying. Mind you, this is a product with "Pure Audio" written as you open the box.
I'm curious if others found the issue better or not with the update.
I am perhaps lucky with my hardware, but I can honestly only remember a single pop in the 20 or so hours I've been listening (only had it about 3 weeks now). Sorry you are still having problems when others don't seem to be (as much)--that is super annoying. I feel like there are enough examples of this (still) that we all should be able to isolate this down, but it doesn't seem to be a distinct pattern or use case from my reading, unless others are seeing a pattern I haven't.
But Chord said it's software-related, hence, why they tried to fix it with an update. It sounds like there's enough people still getting it.
Can those who say they do not experience pops and clicks also state whether they are using SD cards or playing through wifi/ethernet. I am experiencing the pops andclicks when using SD cards. These are large new generation SD cards (500 GB each SXDC cards).
pre-update i heard VPaCs through SD card playback disconnected (hotspot mode) and connected via wired ethernet. since the updates i have heard VPac one time and i was connected via wired ethernet. i haven't had time for much critical listening though since the updates.Can those who say they do not experience pops and clicks also state whether they are using SD cards or playing through wifi/ethernet. I am experiencing the pops andclicks when using SD cards. These are large new generation SD cards (500 GB each SXDC cards).
It is all software related indeed, I am pretty sure of it since my 2GO performs significantly better with this new firmware.
So it is BS that people claim their 2GO is perfect.
You won’t see airplanes fly if the Boeing 777 had such bad software and claiming “our bad engineering only affects a small group of users so our planes are fine”.
Nope, no BS here. I only had the pops and clicks when I still had my old ISP-provided router.
I haven't had any since, both before and after the firmware update. Sorry bud
