What are my options if I want to eq hugo2go in a portable setting? Please don't ask why I need to do it... not all headphones are perfect.
You have to do the equalisation before the music is streamed to the 2Go.What are my options if I want to eq hugo2go in a portable setting? Please don't ask why I need to do it... not all headphones are perfect.
I definitely noticed a difference when I got it, smoking some herb... It may have been all in my head, or lungs, though...Ey guys. Question to my dear 2go owners:
I have a Hugo2 which I happily run with a LG G7 with UAPP via a USB cable. Set-up wise, I do not find the cable annoying and I use Tidal and have enough GBs in the phone. So I ask you sound-wise, have you found a sonic improvement using 2go?
Using HD800 and Ch2 with MBP and jitterbug( only time I use it), no herbs just glass of red wine streaming Mogwai via Qobuz.... sounds satisfactory 2GO arrives on Monday.......Probably it is better to use the jitterbug then.
I never did a direct A/B comparison since it is pain to remove the 2GO (it is screwed onto the Hugo 2), but the jitterbug also improves the Hugo 2.
Dammit! CAN SOMEBODY TURN THAT PIC AROUND!Using HD800 and Ch2 with MBP and jitterbug( only time I use it), no herbs just glass of red wine streaming Mogwai via Qobuz.... sounds satisfactory 2GO arrives on Monday.......
Must be the Jitterbug interferingDammit! CAN SOMEBODY TURN THAT PIC AROUND!
Do you not find the HD800 plus Hugo2 too bright?Using HD800 and Ch2 with MBP and jitterbug( only time I use it), no herbs just glass of red wine streaming Mogwai via Qobuz.... sounds satisfactory 2GO arrives on Monday.......
In all seriousness, I am very glad to have bought the 2go. Like you, I had previously connected my Android phone to the Hugo 2 with a usb cable. In my experience there was a clear improvement in sound quality when I switched to the 2go. I mentioned the specifics a few pages back in this thread.Ey guys. Question to my dear 2go owners:
same position and will get my 2Go on Monday, a bit concerned but hope it will work out, as long as I can stream High res from tidal or qobuz via Iphone on the go and from several ssd, I will be happy camper, if notIn all seriousness, I am very glad to have bought the 2go. Like you, I had previously connected my Android phone to the Hugo 2 with a usb cable. In my experience there was a clear improvement in sound quality when I switched to the 2go. I mentioned the specifics a few pages back in this thread.
Moreover, after the direct connect - phone to h2 via usb - I got a Bluesound Node 2i because my phone just couldn't hold all my music. Again, the 2go was noticeably better in sound quality. So I sold the Bluesound. The 2go is a keeper.
I do have a couple of caveats. I have not done a blind A/B test of the different setups. If someone said that I would not be able to tell the difference blind with levels matched, I would not argue vehemently.
Second caveat: the Bluesound software was rock solid. No hiccups. No wifi issues. And indexing was much quicker than with the 2go. As others have said, we're kinda beta testers for Chord, which I don't mind because I'm confident that they'll iron out the wrinkles.
Yes, at Times I do, but it is depending on the recording, e.g 60 ties music, yes, electronic, no, rock.....depending, vocals or classic guitar, no.. so very much dependent on the quality of the recording and your music taste, and also my 2 cents, the transparency, openess, wide soundstage and instrumental placement is so far unbeatable...... but as you say! Bright! Yes/No but I honestly wish for some more meat/body on the bone to the music and maybe some additional extended bass(not bloomy but firm) and I agree with you for sure, i will not get rid of these but only complement so I am future wise looking at empyrean, if anything else on the horizon that could add, I am all ears!Do you not find the HD800 plus Hugo2 too bright?
Right, but what if I'm playing from the SD card?You have to do the equalisation before the music is streamed to the 2Go.
For mobile use that means using an app on your phone or tablet, and then streaming to the 2Go.
