I have written a review (in German). Here is a (very) short version of the main points.
Packaging & Accessories
Minimal. Go buy yourself a case and I also recommend SpinFit CP-145.
Design & Build
I am not a fan of the bling-bling metal housing. It's highly reflective and it could be a bit more ergonomic. The nozzle is very long and makes it a bit more difficult to find the correct fit than necessary. But I have no issues with the build quality.
The cable is good. Copper-clad aluminum is actually quite cheap and not the preferred choice for high-end audio (because of high resistance), but the 8 strings are very flexible with no memory. It does feel good and is user-replaceable. I think a new one costs 299 CNY which isn't expensive. Channel separation is very good.
Sound
Wow. Whatever your expectations, increase them! This is basically the best dynamic IEM I have yet heard.
Based on my friend's measurements over at
Headflux.de, I have compensated the curve in REW, smoothed it and manually corrected the resonance (7.5 kHz) peak to my personal hearing (9 kHz). The outcome of my subjective perception looks like this:
This is indeed very close to the original frequency response released by 水月雨 MoonDrop. I think our targets might be very similar.
The bass is very good. You can hear the boosted sub-bass but it's not overdone. The coloration is minimal and the Kanas Pro Edition (KPE) does not sound boomy or even punchy. It sounds accurate with some added rumble. It's not a well-textured bass - which is typical for dynamic IEMs, but some prefer this as the perception is closer to the physical impact of loudspeakers.
The midrange is awesome! Tonally accurate but most importantly detailed without any fatigue. The resolution is very high and I managed to pick up small cues that I never thought dynamic drivers were capable of - like doubled voices on the track, clipping in the mastering, small recording errors, etc. But none of them jump at you, the music is always the priority.
The treble has a bright tilt, e.g. it starts slightly recessed and then picks up and peaks at 12-13 kHz. This creates a slightly fuzzy sound with higher notes and many cymbals on Rock records, which mostly hit at around 6-8 kHz, are not as pronounced. The dip does remove any threats of sibilance, so don't worry about sharp S-sounds. Just a few trumpets sounded slightly hot to me. Harmonics are boosted which gives the illusion of increased resolution but also faster decay. It's a preference that I personally do not share. But overall, this is nitpicking and the treble presence is there where it belongs. The extension is superb. (In fact, I don't know many IEMs that actually manage to get the highs just right so I could criticizes whichever IEM you name me.)
Soundstage is not the biggest I've heard but decently wide. The somewhat neutral tuning cannot create the depth of a v-shaped bass-boosted IEM but on the plus-side imaging is better. As I already mentioned, the resolution is top-notch. It does not sound like a multi-BA. It sounds softer but the microdetails are all there and the KPE performs better in the midrange than some TOTL BAs that I've heard. (I don't want to bash your favorite IEMs so I'm keeping it general.)
BTW, MoonDrop advertises extremely low distortion. I don't think this is something ears can easily pick up or is a make or break criteria, but my friend can confirm that his measurements have shown very low klirr factor.
Verdict
I really love them! On my list of favorite IEMs (short version in my profile), there are but two dynamics and both of them budget-tier. I want to place the KPE next to StageDiver 2 and Etymotic ER4 XR - or even above them because of the formidable extension on both ends. I could actually imagine using the KPE for professional monitoring, but they sound almost too enjoyable for this purpose.
Recommended for:
- Fans of the Sony MH1 that need an upgrade: The KPE will give you a more accurate tonality and a much improved resolution.
- Maybe for fans of the CA Andromeda. Not the stock 0 ohms version, but if you like the Andros at 3 ohms OI, the KPE could be the dynamic version of that.
- Users that randomize their playlist with all kinds of genres. EDM, violins, complex Jazz, Concerto, Rock, .... whatever. I can't think of a genre that would not be suited.
- Users that enjoy a good midrange but do not want to neglect bass and treble.
- Users that do not have a high-end source. This IEM does not bend at all. You can throw 100 ohms OI at it, it will sound the same as with 0 ohms. Just stay away from hiss, I can actually hear it with the Nintendo Switch.
- Finally, users that usually do not like dynamic IEMs and might have underestimated the capabilities.
Not recommended for:
- Fans of v-shape signature or big bass. The bass has a mild boost only.
- Users with very fit-dependent ears. Fit is not bad, but there are quite a few UIEMs that are easier to get a seal and a secure fit with.
- Users that do not want to blind by-passers in the sun. The metal housing reflects like crazy.
