Slater
I loved the sound these originally had, but find the newly opened vent to make them too bass-heavy now.
To control the bass, you have to retune the driver vents with tape.
Would I be bumping up to solid tape? I haven't touched any of the existing micropore tape, so it's still covering all the rear ports and the outer ring of face ports - same as stock. I could try and cover some of the face holes that're directly over the driver the way the stock Akai does, but I'd expect that to start affecting treble, not bass.To control the bass, you have to retune the driver vents with tape.
I just punched a big hole in the shell because I wanted to try these cans fully open.
Aside from the backs, I also shaved off most of the port shroud to improve cable compatibility, and replaced the 3-pole jack with a 4-pole so I can use my balanced Sony cable (both negatives are next to each other, though, so a standard 3-pole cable still works fine).
The included velour pads actually don't sound so bad now that the bass has gone up so much, but they're not as thick as the stock pads, so my ear's pressing against the shell. The stock pads were getting kind of hot anyway, so I'll probably still replace them with a set of Brainwavz - I'm just not yet decided if I'll go Hybrid of Velour.
thanks.
i didnt like their look. and are they better than Pro 82 ?
Hi I am looking for a chifi headphone that can replace my audio technica ath-m50x, max budget 200 usd. I only use Iems so I do not know much about headphones, but my prefered sound is harman target/neutral just like my Moondrop KXXS.
I will however use the headphones for gaming but if it sounds amazing with music then that is good.
Currently looking at the Blon B8: https://www.amazon.co.uk/BLON-BossH...sr_1_1?keywords=blon+b8&qid=1570449555&sr=8-1
edit: playing with Fiio M11 or Asus xonar u7
i love bass in songs when listening Pop or club music... alternative and country i like generally.
big head, not litte or not supersized, normal or a bit bigger.
over ear or on ear doesnt matter actually, just used over ear takstar hd5500 for years. if it is strong, will not be easily broken by my 2 years doughter than i can try on ear.
using at home.
thanks.
I already have an antlion modmic that is attached to my headphone so I do not need it.Sounds like both of you will enjoy Takstar GM200, currently available around 56$ - https://www.head-fi.org/threads/tak...scussion-thread.849965/page-197#post-15148815
The bass is very addictive, great soundstage and imaging, plus a microphone for gaming.
Does the magnets from the modmic affect the magnets from planar headphones?
I might try a light application of fiber fill in the cups to rein in the bass a bit more.
So while modding my HAS-30 for a more open back, I realized the shell design's a bit different from the Akai 50X that Slater demos. A 42mm grille won't fit without cutting, and the bevel prevents any sort of press fit, so I'll be gluing in a ~35mm grille instead.
I happened to have a few of these louvers left over from another project (https://www.amazon.com/gp/product/B00QC2I2KA/ ). The 25mm cylinder can be pulled out with a pair of pliers, leaving me a 35mm vented disc that's just a hair under the flat diameter of the shell once the logo-mounting bump's ground out.
Currently waiting on the matte black paint to dry on 'em before I remount and share photos.
All that said, I loved the sound these originally had, but find the newly opened vent to make them too bass-heavy now. I'll re-try the velour pads that came packed with the phones, but I expect that to drop the bass too much (they sounded hollow last time I tried them with the stock shell), so I may go for some Brainwavz round hybrids next.
As a side note, the OneOdio's inherited the stock pads from the Stellar Lab's. They also had their fibrous paper that was covering the driver side removed (scraped off with a razor blade). Big improvement there. Subjectively they now sound even better, bass gets deeper, mids and highs are cleaner.
Can you provide a photo of the mod you did to the Oneodio? I have a set that I really enjoy and wouldn't mind possibly modding if it's not too involved/ reversible.
I'd say it isn't reversible unless you were to buy some of that fibre-paper and re-glue it on.
It's fairly straightforward. I also believe someone else in this thread mentioned this mod.
Basically all you need to do is remove the earpads and you will see a circular piece of fibrous paper glued over the output of the the headphones. I tried to dissolve the glue with a solvent, but ended up just using tweezers and a razor blade to scrape it off. As mentioned I then also replaced the earpads with the surplus ones from the Stellar Labs.
Since I did both at the same time I can't say with certainty which modification had the greater affect on the improvement in sound, but it seems reasonable that the fibre-paper would very likely be restricting the sound somewhat. I would say the larger pads mostly contributed to the bass response improvement, and the paper removal to the clarity improvement. Larger pads also increased the comfort level, not that the stock OneOdio's pads were uncomfortable to begin with anyway
Edit: I added photos, but I believe my post count is too low for me to be authorised to do that, so they didn't attach.
