drag0nslayer
Looking for monk IE bundle also, did you find it anywhere ?Hello HF members,
Last week i've bought the Xiaomi Hybrid Pro with an impulse buy because they were on sale for about $17. I've instantly bought them because I have had the Piston 1, 2 and 3 versions all before and enjoyed them. However I always had the problem of 1 side of the cable dying after about a year of use, even when always using the supplied storage unit where you wind the cable around it. It has been a while since I looked at Head-Fi and really looked into what is available on the market now, but i'm starting to wonder if these Xiaomi Hybrid Pro were a good buy, or if I should return them when they arrive. I've looked into a few alternatives now, and wonder what would be recommended. Max budget I would spend on them is about $60, and detachable cables might be a preference, because the cables always seem to break on me after about a year of usage, and replacing a cable is of course cheaper then buying new IEM. With 11.11 incoming, there are a ton of ice discounts coming, so this is the list I compiled.
All sales on AE unless noted otherwise
Which of these would be the best choice? Is a $60 IEM that much better then a $20/$30 IEM? If there are other recommendations feel free to point them out.
- $11 KZ ZST (now on sale at gearbest)
- $18 KZ ZST Pro
- $25 **** 4in1
- $26 BossHiFi B3
- $33 KZ ZS6
- $34 Zvara Red
- $34 Tin Audio T2
- $45 OVC H15 (Amazon.de)
- $60 Shozy Hibiki
- $60 VE Monk IE bundle package (If I can manage to buy it)
Any recommendations/feedback is much appreciated!
AND
if i were you i'd definitely chose B3,Red and T2 and Monk Ie bundle if its available.
But for your budget If Monk IE is available then go for it else B3 and Red is under your budget.
