The new update has made doing anything on mobile, other than reading, impossible. No liking posts, no quoting, no replying, nothing. I'm using Chrome on Android 7.0. I don't always have access to a PC and do the majority of my Head-Fi'ing on my phone. Perhaps the drop-off is due to other having similar issues.
Yes indeed. On mobile I basically can only read. Hard to believe they rolled out this change before working out such basic issues. Really dampens participation on a forum when you can't...um...particiapate.
That's sort of how I'm feeling about the Seafh AWK009 I just received from Amazon today. Compared to the KZ ED9, they really don't sound very good. Also not as good as the Rock Zircons I got last week.
In order of my liking:
1. KZ ED9 (robust sound for IEMs while using wide filters)
2. Rock Zircon (clear sound, but weak bass)
3. Seafh AWK009 (harsh sound, exaggerated highs, weak bass)
BUT, I will be playing around with EQ settings for each pair in order to find a sweet spot.
From the impressions you've given I think you need to invest in some foam eartips or at least find some silicone ones that fit. Rock Zircon's are bassy, too bassy in my opinion. You're obviously not getting a seal in the ear.
It could be a similar issue with the Seahf, whilst they have a v.strong treble they aren't harsh. They are brighter than ED9 so maybe the ED9 is your limit in terms of brightness though.
Sorry to be the bearer of bad news, they just didn't sound right. If I'd been reviewing back then I might have tried to figure out what was wrong with them.
