I will skip hifiman IEMs due its short durability, I' will check IM50 and M4 for sure, specially the M4.
Thak you!
I'll read it! If I have a question Can I send you a PM?
That's the IEM and post I was looking for... and under $30
Thank you!
I want an IEM similar to xe800 and more bass is not a must, but less... I don't know. Thank you for the info!
I belived urbanfun was a warm earphone, I will check it
I really don't like a v-shaped or warm sound signature so... I think I'll skip these ones.
Thank you!
I wouldn't consider either the X5 or HLSX 808 as warm though you could say they're v-shaped. Both are a little thin in the midrange. The 808 has amazing resolution and detail but vocals are recessed.
