burgunder
- Aug 19, 2004
Fostex TE-02 are also neutral and cheap.
If you are looking for something neutral, the XE800 is not only the best 'cheap' iem, it's probably the best sub 100$ iem you can get.
It's good but there are better under $100, in fact I think there are better for less than the XE800.
Fair enough, why not recommend them then? I would also be interested in learning about actually neutral iems that are more capable than the XE800 at those price ranges.
In relation to OZZERO's post as he wasn't specific about being neutral: -
Einsear T2
Urbanfun Hifi
Mannhas C190
if you want to go up a bracket in price Ty Hi-Z G3 have great soundstage and are detail masters.
I listen mainly to dance music so something with some bass is what I am looking for. Which one of those would be suitable?
I thought I'd share my experience with everyone regarding Paragon Audo Store (not a typo)
I bought some 'Silver Plated' MMCX cables from them to use in making my own earbuds. The plan was to remove the MMCX plug and solder to the driver, however the cable is just normal copper not silver plated, blue cable below vs genuine silver plated black.
At first I thought this was just an error in the listing and the seller would sort out, he's now claiming that this is a 'language issue' and silver plated in China means 'no silver at all'.
I thought I'd share this as a warning about the honesty of Paragon and a general warning regarding buying 'silver plated' cables from China. I have a list of trusted sellers which I'm happy to share (is not very long) if anyone is looking. That's what you get for going off piste.
If it's for EDM then the XE800 are aren't going to be right for you.
Urbanfun or Einsear would be the best but from that list but also consider Senzer H1 or **** 4in1
You don't say where you are - if you're UK based you can get the Senzer from Amazon next day
Hmm both are too pricey for me. Yes I'm UK based.
Is the Einsear T2 better than the KZ KS3, ATE/ATR or Joyroom E109?
In my opinion the T2 is better than any of the ones you list although I've only heard the ATE S out the the many ATE variants.
What's your budget and are you sourcing from China or UK?
Yeah I'll probably purchase from Gearbest or Aliexpress. Looking to spend no more than £10 really.
That narrows it down a bit really only the Einsear T2 in that bracket. I would have liked to had another listen to confirm my impressions but I've left it at my Dad's house. Honestly thought it was on a par with more expensive earphones.
I will say I really like the ZS3 as well, it's got a lot of character and enough bass for dance music
@1clearhead
Try the foam tips on the K3. It tames the harshness and improves the mids. I think you'll like it more.
