Do all tips fit every IEM? Or.. if not what would be some great double or tripple flanged tips for a pair of Linsoul TFZ No. 3?
Also what does foam do compared to silicone?
Nope, u gotta know the diameter of the nozzle of your IEM. Some models like Westone come in a very thin nozzle, some come in larger nozzle diameters.
Foam tips in general tends to tame the treble, but do note that foam generally needs to be changed every few weeks as they disintegrate.
Silicone tips generally last longer. This is rather dependent on eartip anatomy, so YMMV, but I find in general narrower bore silicone tips tend to increase bass, whereas wider bore silicone tips tend to increase treble.
The TFZ No. 3 actually has a big assortment of eartips included (silicone), they have wide bore and narrow ones. I find the No. 3 is a basshead set, so if u are bass averse, you might get a better balancing of the bass when the wider bore tips are used. I find the narrow bore ones make the midbass bleed on the TFZ No. 3 too pronounced due to the copious bass quantities. Haven't tried any flanged tips with the TFZ No. 3.
