Nimweth
I have the Tin Hifi T4 coming next....looking forward to that!
I agree with you about copper cables, they can help to obtain a warmer tonality and improved bass whereas I find silver plated cables can give a brighter result which can help with treble roll off or recessed mids. Uh-oh! Controversial!!!How to handle the treble on the T800?
1) Knowles filters - see Audiosense thread
2) Change eartips - foams or spiral dots seem to be the general consensus in the Audiosense thread
3) Copper cables instead of stock SPC - this is controversial in audiophiledom about cables, but personally, I find the treble is tamed to my tastes with copper cables, and this is the only mod I use on the T800. I explored many permutations, and I don't use knowles filters or aftermarket tips currently.
4) EQ
5) Can consider other mods like teabag, animal foam mods in nozzle etc.
Yes, I tried a copper cable and a silver plated cable on my TRN BA5, and the copper one helps with the BA bass, whereas the silver plated one sounds a bit too bright.I agree. I have a 16 core copper and a silver of the same. They sound different.
Got some more stuff coming, can anyone guess what?
Hint: The moon is one drop away with my nameless spaceship.
Anjirui and Misodiko. Both great choices, and both available via AliExpress. Anjirui are IMHO the best "regular" type foams, while Misodiko are more like Sennheiser foams - less squishy, but denser, more solid.Wonderful and quick feedback, @Tonymac136! Thank you very much. All the tips you mentioned (and more) are on my list. I picked up a set of Final E tips just the other day, and I am already keyed into the good deal on Spiral Dots on Penon. I am ordering a couple sets of generic "Sony" Hybrids to compare with the authentic sets I have. I may pick up some Spinfits on AliE, but I think they may be roughly the same price on eBay (I will check).
Besides Comply and Dekoni, are there any good quality, less expensive foam tips out there? Tennmak sells "ultra foam" tips that they advertise are much slower rebound and more durable then the generic red/blue imitation Complys. Any experience with these?
...I also have a bunch of Auvio (Radio Shack) tips now, which @Slater called "poor man's spiral dots"
Generic foams are mostly awful quality from what I have found. Dekoni Bulletz are much better but not very squishy if that's your jam.
Starlines, whirlwinds, spinfits are all available on AliExpress. You can also get copies of Sony Hybrids which are decent enough.
Outside of AliExpress, Spiral Dots (available from Penon for cheap), Symbios and Final Type E are all worth a look for a selection to choose from. Spirals are now more or less my default.
Ooh thanks. I'm a bit off foams as they thicken the bass a bit much but I struggle to get a good seal with silicones so I might try the others.
Flare audiophile earfoams are on sale half price ATM which is three pairs for a tenner. They don't thicken the bass, or at least nowhere near as much as standard ones due to their wide bores and "acoustic lens" geometry.
