DynamicEars Thanks for you impressions on Spring 1. I noticed you have CCA C10. I have them too. How do you find this two in comparison. Also how far Spring 1 from IER M7? And is this really that simple just to remove cloth grill to make that much difference?
Thank you.
CCA C10 while quite smooth for KZ/CCA, they have mid bass bleed, slight emphasize on 2.5khz, but they dont have the resolution, dynamic, soundstage, details as on Spring 1. I even much prefer BLON BL-03 by much. Spring 1 have more resolution, clarity, better timbre, better bass articulation and decay, but you have to find the correct eartips, and turns out wide bore with shallow nozzle to be best to be paired with. And after removing cloth mesh below the grill, clarity is exceptional and suddenly the timbre become so natural. I have to admit, previously i write timbre is same with blon on ootb Spring 1, but after some sessions BLON is more natural
@baskingshark but after cloth removal, everything changed like day and night, its much different in almost all area. Bass no longer bloated and messy, mids become so clear, soundstage become much more natural (previously they have good or bad larger than life / gimmick surround effect) with same width. The only negative so far is more prone to sibilance, but I found them still very safe for me (im a treble sensitive and prefer rolled off treble hence i pick M7 rather than M9). But
@kukkurovaca experienced sibilances from his story. Im using silver plated cable, neutral DAC DAPs, also with usb DAC sonata HD also very much safe. And i like to listen in high volume.
vs M7, soundstage maybe around same width, but imaging and layering on M7 is sooo good that hard to beat or catch up (they are so precise, i like them more than Andromeda and sub bass - bass area also). But of course M7 is like 5 times pricier (or maybe 4 with discounted price). Separation also better in M7, clarity is the one that Spring 1 can hold off against M7 after cloth mesh removal and details also not far behind the M7. So for the price I found Spring 1 really hold great value, like BLON in their class segment.
Do you like your C16? I cant compare directly but my memory of impressions about C16 is detail monster but its harsher, and much brighter. Take it with grain of salt of course
