so Tin Hifi audio T4 is 10mm single Carbon Nanotube DD like BLON BL-03. Or BLON BL-03 was stealing the same driver than meant to be use in T4 because they saw there was an OPPOTY.
This is interesting since TinAudio / TinHifi also have good reputations in tuning.
Is there a Chinese DAP that pairs well with T800? I am looking for good detail, dynamics and resolution, with no hiss.
So far I am using my older Onkyo DP-S1 Rubato (very good sound), and also loved the perfect sound of pairing with much more expensive Sony NW-WM1A. Is there a Chinese DAP that matches or exceeds these?
Yes seems like it but i think its better tuned and it has a better shell. The secret on this shell is to use foam tips und put them down all the way to the nozzel and block the air vent.
Considering that the Tin T2, T2 Pro, T3 & the P1 are all light, in the very low range (without taping ports or EQing), I highly doubt that they'll go against their company's past frequency target.
T4 emphasize about DESIGN.. well they copy from sony flagship IER Z1R combine with Aeroplane Turbine. From BGGAR FR, seems like finally Tin got bass now, graph more or less similar with BLON, with lower bass quantity. I think these will be sounds good, but will be very similar to BLON
Yep, at least from my experience. A lot of stores makes a lot of adjustments, mostly downward, during the actual sale. I'm sure it depends on how much product they're moving and what their competitors are doing.
They each have their own little case... here is what was lying around when I took this photo a while back. As you can see, we label them all.
Then all the little cases go into travel cases (which are kept in the closet... or on the floor, lol. This was taken a year and a half ago. At the time I did not plan to buy any more cases. I thought I was done. But when you read threads, temptation and curiosity set in. Be aware!
At the time there were also two cases of earbuds not shown here. Now there are more of both. I have one kind of big case filled with the buds that my husband makes for me.
I would not dare take a photo of my husbands desk right now... or the floor around it but mine is not too bad at the moment. Not sure what is going on with all those eartips next to the orange lamp though... lol. The aftermath of a few tip rolling sessions. You can only see them if you zoom in and even then some are out of sight.
