NLcobra96
- Nov 1, 2016
Anyone gonna order the Moondrop IX?? Peaking my interest
have ordered and on the road
My thoughts exactly! Same exact shell
Nothing specific but try to find a BA only IEM, 2 BA and up should give you what you need.Hello, I stumbled across this thread and thought I’d see if anyone had any recommendations for a universal IEM. It would be for commuting only and so I want something with very high isolation – deep fit and will take foam tips.
In terms of sound I would like a dynamic sound with enhanced bass and treble (more treble focus than bass) and clear vocals especially female. It doesn’t matter if the sound is fatiguing as it will only be for commuting not long listening sessions.
I would say isolation is the priority so I’m willing to take a slight hit on sound quality, though obviously the best sound possible. No real budget limit. Thanks for any recommendations.
I don't know about Series 1 but Series 5 and KZ ZST have the same shell shape.
theres two suggestions I have for you, although both not V-Shaped they have lovely treble and mids.Hello, I stumbled across this thread and thought I’d see if anyone had any recommendations for a universal IEM. It would be for commuting only and so I want something with very high isolation – deep fit and will take foam tips.
FIY, hifiman re400 brandnew sale for nearly 35$ on tmall
Grab itttttttttttttt
Read the reviews on the etymotic hf3/5 and the VE Duke. The Duke comes with different cables, the duo 3.5mm is a bit unwieldy for on the go but I think it comes in a single cable version of using single ended. Both are tiny for deep insertion for isolation.
Thanks. I've heard the Etymotics and they weren't for me. I'll look into the Duke. My only concern is it seems vented and so the isolation would be affected.
I know you said you preferred universals, but I would at least take a look at the Custom Art Music One. It's a fairly inexpensive silicone CIEM that sounds amazing for the money. The isolation you get with it as well is mind blowing, even if you've never gotten any sort of CIEM before, I'd heavily consider it as it sounds like it would fill what you are looking for fairly well.
Maybe he means the K1? As for me i'm curious about how the Magaosi M3 fares against the 3 driver K1 you got earlier.
