Chinese $10 USB Audio Controller Review (I'm serious)
Sep 17, 2007 at 9:05 PM Post #106 of 129
Originally Posted by daveyostrow /img/forum/go_quote.gif
so is the $20 TBAAM a better buy (sound and value) than the $5 3D stick?
Yes, because a lot of the $5 sticks are garbage.
Personally though, I think im going to go with the iBasso D1.
Sep 30, 2007 at 2:24 PM Post #108 of 129
I bought 2 3D stick and works fine on my desktop XP, but on my Compaq Presario laptop makes clicky sound. Quality of sound seems same as the TBAAM on my desktop.
gychang
Oct 1, 2007 at 11:06 PM Post #110 of 129
If you could, that wouldn't be a bad idea, it'd actually probably be pretty easy. I'd try it first if I hadn't already given mine away. (Upgraded to an EMU0404)
Oct 1, 2007 at 11:35 PM Post #111 of 129
That sounds like a good idea. Its not like ive got anything to lose...
Oct 2, 2007 at 4:24 PM Post #113 of 129
Ya, I don't have mine with me though, so it'll be a couple weeks until I take a look at it.
So you would basically just rip the opamp off and put wires in place of the pins?
Oct 2, 2007 at 4:27 PM Post #114 of 129
Micah - Nice, I have two of those myself and use one at work and the other at home. Works fine in Linux as well.
Oct 2, 2007 at 5:58 PM Post #115 of 129
The chinese sticks work in linux? Mine didn't work. At least not plug and play...
Oct 2, 2007 at 7:49 PM Post #116 of 129
I've never had a problem with USB sound devices in Linux. I use Ubuntu Feisty Fawn.
Oct 3, 2007 at 7:37 AM Post #117 of 129
I think I would try with some probes as line out connected to a cheap old amp and speakers of some. Then you could hunt around for the line out signal to save distroying it, before I knew if it would work.sort
Oct 7, 2007 at 8:49 PM Post #118 of 129
Originally Posted by nightfire /img/forum/go_quote.gif
I personally recommend an M-Audio Transit or HagUSB.
Never heard of these...interesting!
Oct 9, 2007 at 4:49 AM Post #119 of 129
Oct 27, 2007 at 8:21 PM Post #120 of 129
Got my .99 cent unit today...exactly the same one that spudman showed us on the ledshoppe.com web page. SURPRISE...SURPRISE...didn't work! My Toshiba M65-S809 wouldn't recognize it and also said that the unit was malfunctioning. When plugged into the USB slot the 3D SOUND LED's would light up...1 red and 1 green and then the green light would flicker and die out. No sound at all through the headphone connection. I guess that you get what you pay for!! Not a recommended product!
