SK138
- May 15, 2005
This all started with successful experimentation with two cMoy (build by blackinches) in a balanced configuration and finding Iron_Dreamer's post:
Long story short, with above experimentation and Iron_Dreamer's inspirational post, I jump to balanced system using two VHP2 tethered to two VAC power supplies. You can read my long story version on my sig link on the balanced cMoy
The following comments and observations are my own opinions. This is NOT meant to be a critical review since I know I really suck at any formal reviews. I just want to share in an alternative possibilities in this fun hobby and share in my elation of going balanced. I am not comparing it with any other balanced amp since I never actually owned a balanced amp..until now.
I did own over 25 single ended (desktop and portable) amps in the past. Plus I had over 35 unique headphones along the way. So...at my ripe old age, I know the sound I prefer. I listen to anything but rap, country, and metal. My number #1 musical preference is towards anything with female vocals; jazz, pop, rock, trance, etc. Since balanced configuration doubles the gain, I only listen to VPH2/VAC^2 in lowest gain setting. I am also using iTunes as source and master volume control.
Without further waiting....[size=x-small]BAM!!![/size] CIA Balanced VHP2/VAC^2
The mirror finished aluminum case above the CIA gear will be the housing for my balanced cMoy system once blackinches mod it some more.
I still have not burned in the recommended 100 hours yet. Here are some comments and thoughts that pops up in my mind as I am listening to it now:
* wow...the bass is really deep and tuneful without ever dominating the music
* It sounds very powerful even at low volume
* wow...the channel separation is awesome
* micro detail without being harsh
* it's the most 3D sounding system I have ever heard
* more "air" between notes
* lowest noise floor ever (like a black-hole)
* treble energy is never harsh
* sounds very smooth and effortless
* Senn veil is lifted
* it's fun sounding
* wow....I never had this much fun
...it can only get better
It's true, Senn HD650 transforms to a different animal in balanced mode. I will just leave it at that
I also have balanced Mini^3 coming my way from John (aka blackinces)
Originally Posted by Iron_Dreamer /img/forum/go_quote.gif He does, it's called two VHP2's. Considering that the VDA2 has RCA output jacks, it's easier to hook up two single-ended headphone amps to than any other DAC I know of. Just put two RCA cables from L+ and L- outputs on the VDA2 to the L and R inputs of the VHP2. Repeat with the R channels and another VHP2. Rewire your headphone to have two TRS jacks instead of two XLR for most balanced amps, plug into the two VHP2's (remembering which is the L and which the R channel), and BAM! an all CIA balanced headphone rig! |
* it's fun sounding
