Nov 14, 2013 at 8:55 PM Post #17 of 28
I already auditioned the GR07 MK2 before and that's probably the best IEM I ever heard. I'll let you know once I test the GR07BE.
Nov 23, 2013 at 6:34 AM Post #18 of 28
I just got my Vsonic GR07BE. They are quite good out of the box. Hope the soundstage and bass extension improves after burn-in.
Dec 1, 2013 at 11:08 AM Post #20 of 28
My 'burn-in' is just using them normally.
Jan 25, 2014 at 7:12 PM Post #21 of 28
My Gr07 already have a bad contact on the jack plug... They held 2 months... I going to try to fix them, but I expected a 130$ IEM pair to last longer. Otherwise they sound freaking awesome after ~300hrs!
Jan 26, 2014 at 9:22 PM Post #22 of 28
I would expect something that costs $130 to last a lot longer than 2 month. My gr07 seems to be holding well. One of the forumers here recabled his GR07 on the GR07 appreciation thread but it is so expensive.
Jan 27, 2014 at 8:36 PM Post #23 of 28
Here's another forumers GR07 which is giving trouble:
http://www.head-fi.org/t/699088/need-some-direction-please-in-ear-headphone-suggestions/15#post_10211378
Jan 28, 2014 at 1:32 PM Post #24 of 28
ppl need to use a tape to strengthen the wire near jack plus use ear guides all the time to be on safe side.
I even use brainwavz hard case that came with m3
Apr 19, 2014 at 9:57 AM Post #25 of 28
I soldered a new jack, worked quite well... There earbuds are still amazing, just need to replace the jack every 3 months...I guess I use them too much, they are always in my pocket... I'll do as sardar said, I'll tape the new jack for safety.
Edit : forgot to say how they have gotten better over time! They are not sibilant at all anymore, it's just perfect! Amazing for this price, too! Thank you again zamorin!
Nov 21, 2014 at 1:31 AM Post #27 of 28
louis54000,
How did the jack break? Mine is still holding well. I store it in a hard shell case and I don't use them that often now.
Nov 29, 2014 at 1:46 PM Post #28 of 28
I don't know, a bad contact just appeared! Same for the second pair, broken and soldered again.... But I use them every days. I used to take them outside but now I'm using apple earpods (2 years, everything is fine) and I let the gr07 at home.
