Thanks Gusp and Skibum for chiming in on the Dueland VSF caps, yes they are most definitely not just for speaker crossovers. In fact Tony (Driguy) has just put a pair of 400V VSF couplers inside his custom 26 Tube CCS preamp. He now has them in both his 26 Pre and Chameleon DAC, he also reports outstanding results.
Chris over at Jupiter told me that back in the 30's it was common for the wax caps to be flat. (In lots of ways audio reproduction has gone backwards since WWII. I will elaborate further on this subject in my new blog). Well with my constant needling Chris has finally released his "New Vintage" flat Jupiter caps, and yes they come factory Cryo'd. Aluminum foil, bee's wax, and paper, just like the original orange version but now in the new look "flat" format.
Well first off, I am happy to report that 3.3uf Jupiters fit just dandy inside the Chameleon.
Here are the pictures;
Picasa Web Albums - Bill - Jupiter New V...
Unlike the new 600vdc HT Jupiter's which take forever to break in, these flat 100vdc Jupiter's started singing after only 4 hours. And yes just like the Dueland's they too have the big lunar landscape perspective, must be something do with flat caps. From my vantage point all round coupling caps are now obsolete ...
Ok, but how do they compare ... well ... first off they are made out of aluminum, not copper, like my Duelands. (Chris reports that flat copper foil caps should be ready by the end of summer). Compared to my Duelands the soundstage is more brightly lit, I think this would be of great benefit to those with copper hookup wire or whose system could use some more sunshine. Inner detail is there in spades and they maintain overall system balance even with my all silver wire system. Wide open yet relaxed soundstage, another words they're keepers.
Naming names, I really dislike the sound of Audio Note & Jensen copper foils caps. Rolled off, slow sounding, and to top it off they have the curse of round caps. Balled up excess center soundstage energy. This is just plain wrong, no wonder people that can afford them gravitate to custom output transformer solutions. However getting output transformers to work properly is yet another can of worms. On the other hand coupling caps are dirt easy to use ... but they suck in comparison.
Well that was until the "phat" flat Duelands and Jupiters arrived on the scene.
Get yourself a pair and relax.
(Tell Chris I sent you for a 20% introductory discount.)
