Gentlemen,
Rolling through 400 hours on my bone stock pre-production Chameleon and while I would say the DAC is ready for prime time at 200 hours, at 400, there is just more there ... there!
Bad news is I still sense a lack of dynamics and bass so I decided to up the voltage to 9 VDC to the DAC chips. Guess what, turning the variable resistor inside the DC-30 power supply only netted me 8.7 volts no matter how much I kept turning.
Houston we have a problem!!!
The power supply is running out of gas trying to drive the 16 DAC chips. We need more amps, put more coal to the fire! Well fortunately there is an unused 15.5 VAC tap on the R-Core transformer. Simple fix ... I removed the "Blue" 11.5 VAC wire and soldered on the "Yellow" 16 VAC wire. (The transformer incorrectly reads 9V & 12VAC with 2.5A output at 12V, I suspect they mean 2.5A at 15.5 V).
My math shows with 16 DAC chips we need right around 2 amps of current. Obviously with the 12VAC tap we are running a bit shy of that mark. With the 8 DAC chips of the Valab this may have been fine but not with "Big Dog" Chameleon. i set the DAC input voltage to 7.85 VDC and it stayed the same even with the yellow wire soldered in place but please double check.
Botta Bing, Botta Boom!
The Chameleon is now hitting on all cylinders, very nice drive and dynamics. I venture to say, even in stock form, the Chameleon now outperforms my fully modded Valab on just about every measure. Sounds very open and balanced even with the stock Wima coupling caps. Great news for you non-solder heads.
Excellent job Michael.
Note: For those of you who already have a Chameleon DAC in the mail, double check to make sure the 15.5 VAC yellow wire from the transformer is soldered to the board inside the DC-30.
(Stay tuned as I will play with upping the voltage even beyond the so-called maximum 8 VDC limit of the TDA 1543 DAC chip. For now this falls in the "don't try this at home category". Stick with 7.85VDC max input until full testing is complete).
Peace!
