marios_mar
- Jul 21, 2003
BUZZZZ!!
Totally wrong!! Many hyperboles...
Project Phonobox MM/MC phonostage $100
Project 1.2 TT $250
Ortofon MC15 moving coil cart $150
total $500
Now show me a $500 CDP that even comes close to this kind of fidelity, realism, detail etc.
Well there is none, don't bother.
I had a similar combo and a similarly priced CDP. Sure the CDP had a greater S/N ratio and had no noises but it was killed in all other respects.
So the advantages are minor compared to the advantages.
Now with more expensive gear you eliminate the noise/S/N and similar deficiences. You get a more authoritative sound with no major drawbacks other than practical ones like for example that you have to be a careful and not a sloppy person and respect your collection.
And again you can buy music for really cheap!! So even if you buy a cleaner sometime 30 records cleaned (bought at $2-4) will make up for the money spent on the machine.
Originally Posted by Sovkiller With a 500.00 dollars setup in both formats, there is no way you could hear a LP better than a CD....you need to spend a huge amount of money, to get a decent analog sound, later clenaers, and huge space to keep them, and over this, you have to swap he side of the LP very 45 minutes, want more?......thanks I passed long time ago, welcome to the 21st century!!!!! ![]() ![]() ![]() |
BUZZZZ!!
Project 1.2 TT $250
total $500
